It is currently Tue Jul 22, 2025 2:17 pm
PostPosted: Tue Jun 30, 2015 2:58 pm
Boostedmini wrote:
as for the front bar mounts, never seen that before, mine has a full length seam with no notches at all as no overrider as std
Thanks for pointing that out - I've never seen that before either. Looks like a good idea though, stops crap from settling in the seam
PostPosted: Tue Jun 30, 2015 4:20 pm
Goldbrocade_62 wrote:
Those studs are for mounting the fresh air duct for the heater.
I believe they maybe for the horn in the early days
I could be wrong, I usually am.
I have only seen those studs on a few models and just assumed they were for the duct.
I have seen those studs on late K's and early 850s but nothing in between.
PostPosted: Tue Jun 30, 2015 4:35 pm
I had a very early 1961 850, the horn was on a bracket attached to the subframe.
PostPosted: Tue Jun 30, 2015 7:08 pm
I didn't think there was a "seam" but an angle spot welded on to mount the bumper to.
PostPosted: Wed Jul 01, 2015 6:37 am
Not a welded seam as such but once it is spot welded on there is effectively a ledge that traps dirt and crap. A welded seam would be better in that atleast there wouldn't be a tiny gap between the bumper bracket and front panel to trap dirt and water
PostPosted: Wed Jul 01, 2015 9:37 pm
Well may be I should just replace my flimsy brackets with some more substantial ones. Then there is no "seam" to catch rubbish and cause rust. 8)
PostPosted: Tue Jul 21, 2015 8:26 am
Where would the horn originally be on a 63 850? Mine has been relocated to near the brake/clutch tin cans
PostPosted: Tue Jul 21, 2015 11:06 am
From memory mine was mounted inside the front corner of the subby, I can't remember whether on LH or RH side.
