It is currently Fri Jul 18, 2025 5:37 pm
 Post subject: What are these wires?
PostPosted: Tue Jul 06, 2004 10:03 pm
There are 2 wires comin out of where my gear stick thingy is like just infront of it, what is it for in a 78model (noob talk :lol: )
I have a problem.. apparently
PostPosted: Tue Jul 06, 2004 10:04 pm
i'm guessing dude....but maybe reverse lights?
PostPosted: Tue Jul 06, 2004 10:06 pm
i dont think it has them :? maybe i should look harder.
PostPosted: Tue Jul 06, 2004 10:09 pm
I'm Guess the reverse lights also. If you dont have one you can
PostPosted: Tue Jul 06, 2004 10:14 pm
both brake lights come on when ur reversing i think....instead of reverse lights that is
yeah i guess so hey. thanks again guys :) ill see if they lead anywhere tomorrow.
8)
PostPosted: Tue Jul 06, 2004 10:21 pm
They are wires from the switch (on gearshift) to the reversing lights. These are in the blinkers which have a 2 filament bulb- reversing, for the purpose of.. 8)
PostPosted: Tue Jul 06, 2004 10:32 pm
I'm guessing then you could take these wires into a single lamp on the boot then. I wonder if the they have a current running if not would you take it from the rear lamp to power
PostPosted: Tue Jul 06, 2004 10:37 pm
You could also have then switch a relay attached to a 100w reversing light!!!! :shock:
PostPosted: Tue Jul 06, 2004 10:59 pm
Sd I think you have a couple of ideas Now and so do I :D
PostPosted: Wed Jul 07, 2004 10:00 am
Yes indeed i do :) thanks yet again guys, this forum is like an encyclopedia with a personality i love it :D 8)
PostPosted: Wed Jul 07, 2004 10:12 am
hey guys, im at work now so im not entirly sure, but i dont think i have these wires in my car, but ill check when i get home. Are they all meant to have them?? My car is a 73 clubbie and since ive had it, it hasnt had any sort of reverse signal so now im thinking that it should have!!! I havent looked to see if there is a switch on or near my gear lever. What should i be looking for??
PostPosted: Wed Jul 07, 2004 10:29 am
yeah there i a switch i think on the drivers side of the shifter. just looked...and there is a bulge covered in grease and dirt hahaha 8)
PostPosted: Wed Jul 07, 2004 1:02 pm
Reversing lights (in the rear blinkrs) appeared in late 71 or early 72. So your 73 should have them. 8)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed Jul 07, 2004 6:48 pm
Well i got home and had a look and "blow me down" theres a switch there!!! No trace of wiring though so the previuos owner must have removed all of it. Next question where do the wires go from and to????
