It is currently Sat Jul 26, 2025 11:55 pm
 Post subject: Clubman Seatbelts ?
PostPosted: Sun Jul 12, 2015 7:50 pm
Die Die Die!!
i couldn't help but notice that some leylands have holes in the storage boxes and some don't, i'm assuming that's for ease of access to the bolt mounting retractable seat belts, i have a mini that doesn't have those holes.. im assuming theres no captive nut in there to mount retractables then ?
how has everyone installed retractable seat belts into a clubman ?
 Post subject: Re: Clubman Seatbelts ?
PostPosted: Sun Jul 12, 2015 10:19 pm
_666_ wrote:
i couldn't help but notice that some leylands have holes in the storage boxes and some don't, i'm assuming that's for ease of access to mount retractable seat belts ?
how have you installed retractable seat belts into a clubman ?
The front belts in late clubbies are retractable. I am not sure when they changed from manual to retractable.
The rears are still manual.
Alec
PostPosted: Mon Jul 13, 2015 9:34 am
I once tried to fit retractables into a `67 Mini that had Clubby headrest type seats. The seats fouled the reels, so I fitted std belts.
This car when we got it had been fitted with retractables just bolted to the bins, not captive nuts in the inner sills below the ashtrays. I considered this a safety hazard- in a decent accident it would probably tear the bins off the floor where spot welded.
PostPosted: Mon Jul 13, 2015 10:38 am
I think the retractable belts were fitted as of 01 January 1975 - this is when ADR 4B came into effect and all front seats had to have emergency locking retractable belts as of this date.
+ Too many other classics
PostPosted: Mon Jul 13, 2015 11:48 am
Die Die Die!!
I was by a friend that the pre 1975 vehicles had retractable a mounted as you say in the bins standard, do yours not look standard ?
PostPosted: Mon Jul 13, 2015 2:00 pm
No, Clubbies (and roundy Minis) pre 1975? had fixed front belts, no retractables. Rear bin top details are different, no captive nuts in there. Only the front ones, below the doors.
I now have retractables in my 1970 car, mounted in the original anchor points below the doors. They work fine.
The problem with the `67 car `Barney' I mentioned was the PO had fitted Clubby front seats, and their tilt mechanism fouled on the reels. Couldn't push the seats back. :x
PostPosted: Mon Jul 13, 2015 2:47 pm
Die Die Die!!
Ahh ok, are you able to take a picture ?
PostPosted: Mon Jul 13, 2015 5:00 pm
Here's mine, fit fine with Cobra seats.
I redrilled the reel bracket closer to the reel so it misses the door bin.
PostPosted: Tue Jul 14, 2015 10:51 am
The funny thing about the introduction of retractable seatbelts is that a correctly adjusted fixed seatbelt is actually safer. Less convenient, but safer.
The key being 'correctly adjusted' I suppose.
PostPosted: Tue Jul 14, 2015 11:50 am
Correctly adjusted = you can't reach the switchgear with seat right back. :lol: That's why I swapped mine.
Users browsing this forum: Bing [Bot] and 91 guests
