It is currently Sun Jul 27, 2025 3:54 pm
PostPosted: Tue May 24, 2005 11:20 am
This might sound like a really stupid question ... where prceisely in the car is the horn located? Im just about to go to get my blue slip and my horn shat itself .... I NEED HELP NOW! ... can anyone help me?
Lucas
PostPosted: Tue May 24, 2005 11:35 am
Usually on the left hand side of the engine bay as you look at the car from the front. Either to the left hand side of the brake and clutch master cylinder bolted to the diagonal strengthening panel, or to the far left behind the grille attached to the slam panel.
1965 Morris Mini 'Woody' Traveller
PostPosted: Tue May 24, 2005 11:36 am
mine is on the drivers side, just behind the grille and just above the licence plate
78 Leyland Mini - Prince
PostPosted: Tue May 24, 2005 11:52 am
Mine's on the steering wheel :lol:
Ooh you mean't under the bonnet in your mini :wink:
PostPosted: Tue May 24, 2005 11:55 am
Mine is next to the radiator under the alternator.
Pete
PostPosted: Tue May 24, 2005 12:00 pm
Found it ... its connected to the diff cover directly under the ignition module ... its stuffed .... reason why i couldnt find it ... its about 1/5th the size of the one on my roundie. ....
Thanx guys
