I have read the 'how to' on this here:
viewtopic.php?f=25&t=55421It isn't really a step by step guide on how to make one which would be good as it leaves a number of unanswered questions from people at the time.
-Is the pole best at around 13' long to allow room to move or slide car back and forward depending on where you are working?
-What height does the pole need to be off the ground to allow a full rotation?
-Do you put long bolts through where the front sub-frame was mounted and where do you mount the rear? Looks like DrMini had bolts through back seat, others under the parcel shelf and some onto rear suspension mounts?
I would appreciate any advice or closer pics before my welding mate makes me one. Cheers.
