It is currently Tue Jul 22, 2025 7:11 pm
 Post subject: which carb
PostPosted: Mon Jul 20, 2015 5:42 pm
was talking to a old mini guy he recons he used a std carb 1.5 inch on a super charger I thought they had to be a sealed carb like a hiff 44 is this true or it doesn't matter if they are a suck thru setup
 Post subject: Re: which carb
PostPosted: Mon Jul 20, 2015 6:15 pm
It doesn't matter with a suck through.
PostPosted: Mon Jul 20, 2015 6:24 pm
Thank u very much
PostPosted: Mon Jul 20, 2015 6:30 pm
If it's the sc12 kit you will be wanting a HIF carb though because of the internal float. Doesn't need to be a sealed one though.
You may be able to use a HS4/6 but the float bowl hanging off the side will create issues which aren't easily worked around.
PostPosted: Mon Jul 20, 2015 6:41 pm
Yer it is he sc12 kit the Ben makes still organizing it off him atm so a if I use a std carb I will have issues looks like I am on the look out for a hiff carb any 1 have one :)
Users browsing this forum: fuzzy-hair-man and 73 guests
