It is currently Thu Jul 24, 2025 6:23 am
 Post subject: Stealth Ignition Box.
PostPosted: Mon Aug 10, 2015 7:30 pm
I sometimes wonder what people do and where they go wrong. I sold someone one of my AEOW DISTRIBUTOR ADVANCE MAPPING BOXES and it was claimed to be NOT working so I just asked to send it back to me for a refund. I rigged it up on my own car and it works perfect. I is so simple to wire up, reprogram and use. I just love the way we can now map the Advance curve and Dwell angle through the rev range in seconds on a computer. Then plug the box back in the car and done. No lengthy time to spend changing springs and modifying weights like we used to do in the past. All you need to do is Lock up the Distributor weights so the Advance will be left to the Box to do. Great gadget.
"Let us remove your "SHORTS"
Last edited by Convertible Mini on Tue Aug 11, 2015 7:22 am, edited 1 time in total.
PostPosted: Mon Aug 10, 2015 7:34 pm
They are a great unit. I love my one.
PostPosted: Mon Aug 10, 2015 10:42 pm
Me too. :)
PostPosted: Mon Aug 10, 2015 10:58 pm
So there's a second hand unit on the market then ...;) convertible I might be interested
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Tue Aug 11, 2015 2:32 pm
I have a 69d? Unsure of exact model dizzy on my a+. It has the ignition module attached to the side with a 3 wire connection. Only 2 are used. Will this stealth module work on my dizzy?
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Tue Aug 11, 2015 10:47 pm
The answer is easy to that question. NO. You will need an older type Distributor 59D with the accuspark type Module or one of our Distributors found here. http://www.ebay.com.au/itm/301703003921 ... 1558.l2649
You will also need to lock the weights out so it does not advance mechanically any more.
PostPosted: Tue Aug 11, 2015 10:51 pm
Do you just lockwire the posts?
PostPosted: Tue Aug 11, 2015 11:01 pm
Yes. The kit includes some 0.6mm SS tie wire. You figure 8 the posts then snip the knot enough to clear the body.
There are vids on the Accuspark website.
http://accuspark.co.uk/Blackbox.htm
PostPosted: Mon Aug 17, 2015 8:22 pm
Milatsmadmini
So... Easiest place to buy in Oz?
PostPosted: Mon Aug 17, 2015 10:31 pm
I got mine from `Rob Roy' in Victoria but can't find their eBay store now.
Or buy Convertible Mini's one, they are the same box.
PostPosted: Mon Aug 17, 2015 11:05 pm
Here it is
http://www.ebay.com/itm/Stealth-BlackBo ... d0&vxp=mtr
Users browsing this forum: Bing [Bot] and 100 guests
