It is currently Thu Jul 24, 2025 2:48 am
 Post subject: RE 266 SS cam
PostPosted: Fri Aug 14, 2015 9:30 am
Tell me about the re 266 cam range s or ss etc is it a good street cam for a 1310 please discuss.
 Post subject: Re: RE 266 SS cam
PostPosted: Fri Aug 14, 2015 11:26 am
Laingy has just put an RE266SS one in his 1387 stroker van. We took it up the blue mountains this week to run it in, it pulls like a train from 1500.
Better than the RE83 that was in it, also has much less tappet noise. Top end will be better too but it's not gone past 4000 yet.
Not to be confused with Graham's previous RE266, the 266SS is a different grind.
PostPosted: Fri Aug 14, 2015 4:36 pm
Keep going this is the stuff I won't to know.
PostPosted: Fri Aug 14, 2015 7:20 pm
If you search on 266ss as the search term and GR as the author you'll see what GR has to say about it.
PostPosted: Sat Aug 15, 2015 9:08 am
Thank you.
PostPosted: Sat Aug 15, 2015 3:03 pm
Looking for those who have installed this cam for their impressions.
PostPosted: Sat Aug 15, 2015 5:34 pm
Just my thoughts, GR wouldn't release a new cam grind unless it's an improvement on the last. I wouldn't hesitate putting it in my engine. If it suited my needs.
PostPosted: Sat Aug 15, 2015 5:42 pm
I'm getting the 266SS put in my 1330 build in the new few weeks, I will let you know how I go, really looking forward to this build!
PostPosted: Sat Aug 15, 2015 6:15 pm
It's a good cam.
Good for a fun street car with a bit of motorkhana action for sure.
Better than the original 266 with more torque.
PostPosted: Sun Aug 16, 2015 12:25 pm
I had a 266SS installed into my Deluxe last year.. a good cam for street use with plenty of power.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Sun Aug 16, 2015 3:37 pm
Thank you ladies and gents, I never doubted it would be good and have been told as much but I just wanted some more impressions I think I will be using it.
PostPosted: Tue Oct 13, 2015 3:22 pm
Hi all from Jakarta, Indonesia.
I just bought 266SS from GR and plan to install it in my 1310 mini.
At the moment I use Kent 266. Please share experiences in 1275 engine. Thank you
PostPosted: Tue Oct 13, 2015 4:45 pm
Better than Kent 266, or Graham's original 266. More torque all the way up.
Works well in a 1275 or bigger with either 1.3 or 1.5 rockers. Stick with std or 1.3 rockers on the 998-1098.
PostPosted: Tue Oct 13, 2015 5:16 pm
Went from a 266 gr cam to a 266ss cam on a car I just bought. Apart from blowing the head gasket the 266ss works a lot better.
I find it has more pulling power and its more noticeable down low.
PostPosted: Tue Oct 13, 2015 7:06 pm
Thank you dr mini and danny
