It is currently Fri Jul 18, 2025 10:07 pm
 Post subject: Cooper S grille brace
PostPosted: Sat Aug 22, 2015 12:18 pm
What are diamensions of the diagonal grille brace. Ron Williams cut off a piece for me when I visited his workshop back in '13 and my panel beater has lost it. My brother can fold up one for me. The vertical brace looks narrower :?:
PostPosted: Sat Aug 22, 2015 6:44 pm
Better off buying one, definitely available in the UK if not here. They're not expensive...
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sat Aug 22, 2015 6:48 pm
http://minikingdomonline.com.au/product ... -cooper-s/
PostPosted: Sat Aug 22, 2015 8:47 pm
Thanks winabbey, thought they'd be around..
67 Deluxe
Dry suspension
PostPosted: Sun Aug 23, 2015 9:21 am
My brother made one up using the diamensions of the vertical brace in about 5 minutes. Why pay $37.50 when I can get one for nix?
PostPosted: Sun Aug 23, 2015 9:23 am
That was Minisports price
PostPosted: Sun Aug 23, 2015 6:23 pm
If originality is not important then go for it. :)
PostPosted: Sun Aug 23, 2015 7:13 pm
The repros don't quite match the original pressings in any case, but certainly do their job keeping the latch panel secure with an oil cooler in place.
PostPosted: Mon Aug 24, 2015 5:01 pm
Thanks for your replies. Basically it is a piece channel, which can be reproduced quite easily. Looking at the mounting of the oil cooler, how does it mount using all mounting holes on the cooler.? I have never seen a fitting kit on sale.
PostPosted: Mon Aug 24, 2015 5:36 pm
Doesn't look too involved making one
http://minikingdomonline.com.au/product ... il-cooler/
PostPosted: Mon Aug 24, 2015 6:13 pm
The oil cooler is mounted using 2 brackets which bolt to the subframe as per below. One bolt hole is re-inforced for the hole at back of the oil cooler.The brackets bend up under the subframe and bolt on , a Cooper S should have the 2 holes in the subframe
http://www.minispares.com/product/Class ... lassic/oil cooler.aspx
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Mon Aug 24, 2015 7:06 pm
Thanks for that. I still have the original subframe from my 'S'. I restored a deluxe subframe as it still met specification measurements
PostPosted: Mon Aug 24, 2015 7:43 pm
My oil cooler L brackets are attached to the front valance not the sub frame
there are no holes in my sub frame for the brackets
Mark
PostPosted: Mon Aug 24, 2015 8:43 pm
Mark
Correct, the don't mount to the frame but correctly mount to the bottom of the valance as well as a hole in the top of the apron where the cooler mounts.
Stibbsy I have a genuine one here if you want to borrow it or do you want me to measure it up.
Greg.
PS nice to see your doing some work on the car. Fiona says you have been dragging the chain. Shame on you.
1962 Mini Speed sports sedan
PostPosted: Tue Aug 25, 2015 6:56 pm
Ops meant to say mounted to the valance :oops:
1965 Morris 850
1977 Leyland LS
