It is currently Fri Jul 18, 2025 4:52 pm
 Post subject: wheel flares
PostPosted: Wed Aug 26, 2015 1:22 pm
Hi Everyone,
Will be fitting spaced drums to the van on the weekend, it is getting original dunlop alloys 10x5's put on it with 165 tyres. What would be best flares to fit without having to modify anything, they are for a leyland van. Wheels stick just under a centre metre at the moment with normal drums but will have spaced ones put on.
Thanks for the help.
Steve
 Post subject: Re: wheel flares
PostPosted: Wed Aug 26, 2015 2:40 pm
If it is not going to be a show car then the easiest and cheapest option is the black plastic screw on flares. About $60 a set.
http://minikingdomonline.com.au/product ... w-on-type/
PostPosted: Wed Aug 26, 2015 3:14 pm
If it was me I would go to the trouble and use clubman flares
PostPosted: Wed Aug 26, 2015 3:51 pm
I have Leyland S rims with 165 Yoko A008's and I haven't had to worry about flares.
1 deg neg camber gives me about 5mm inside the wheel arch trim.
Also the A008's appear skinnier compared to the semi slicks I had which also helps.
PostPosted: Wed Aug 26, 2015 5:00 pm
Will def sit out too far with spaced drums, I might go cheapy flares as suggested and spray them.
Stevd
PostPosted: Wed Aug 26, 2015 6:01 pm
Anyone know if they fit a van the same as sedan?
PostPosted: Wed Aug 26, 2015 6:05 pm
Yep, same same.
PostPosted: Wed Aug 26, 2015 6:18 pm
Awesome :-)
Users browsing this forum: Bing [Bot] and 104 guests
