It is currently Sat Jul 19, 2025 6:41 am
PostPosted: Sun Aug 30, 2015 8:10 pm
Anyone know where I can get a build plate? I only have a blank space on the firewall behind the master cylinders where a build plate used to be.
Thanks in advance
Jenk.
PostPosted: Sun Aug 30, 2015 8:32 pm
depends why you want one.... they're not required by law for registration
mini retailers can supply them blank
PostPosted: Sun Aug 30, 2015 8:38 pm
Hi Simon,
The car was registered 5-6 months ago without one.. but I still thought I might run into trouble trying to get it registered, are you certain its not required?
I checked retailers only ones I could find are in the UK for UK vehicles, Id like a local one if I am forced to put one on.
Jenk.
PostPosted: Sun Aug 30, 2015 8:39 pm
It is not required.
For about 6 to 8 months in 1969 the factory didn't even fit any.
PostPosted: Sun Aug 30, 2015 8:53 pm
how hard did you check??
http://minisport.com.au/mini-british-mo ... ment-plate
PostPosted: Sun Aug 30, 2015 8:58 pm
Apparently not hard enough!! I used the search engine typed in build plate but no go off course!
Jenk.
PostPosted: Mon Aug 31, 2015 12:57 am
Does anyone make the BL Australia ID plate?
