It is currently Tue Jul 22, 2025 3:03 pm
 Post subject: Kel Arc spot welder
PostPosted: Fri Aug 14, 2015 7:38 pm
Has anyone used a Kel Arc spot welder. Currently advertised on ebay for $109.
Also at Big Boyz Toys (bbta.com.au), a bbt195 mig welder. Would this be suitable for panel work on a mini.
 Post subject: Re: Kel Arc spot welder
PostPosted: Sat Aug 15, 2015 8:05 am
would it run on a Australia welder, US run on 110Volts
PostPosted: Sat Aug 15, 2015 9:04 am
The spot welder attaches to an arc welder, no issues. The Mig welder is 240 volts.
PostPosted: Sat Aug 15, 2015 11:03 am
Can't complain about the price of the Kel Arc Spot Welder, just a shame about the post..
PostPosted: Mon Aug 17, 2015 9:02 pm
Oops, sorry Mick. I suppose I should have put the post under General Discussion. I'm just new, feeling my way.
PostPosted: Mon Aug 17, 2015 9:14 pm
no!
You misunderstood me sorry. I meant the post as in the freight cost.
No problem here, its all about maintenance.
PostPosted: Tue Aug 18, 2015 12:07 pm
Any body got a spot welder in Brisbane I could borrow ??:)
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Mon Aug 24, 2015 10:35 pm
Hi Simonw where are you in Brisbane and what do you want to spot weld?
Rod
PostPosted: Tue Aug 25, 2015 7:15 am
Hi rod ! Redcliffe .
I have a back end to do and floors . I have a mig but thought rear bumper seams would be better spotted.
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Tue Aug 25, 2015 8:53 am
No problems
I'm using mine at the moment but pm me when you need it and we can work something out.
Rod
PostPosted: Mon Sep 07, 2015 7:31 pm
Finally tried the Kel Arc spot welder out today and confirm that it is a little beaudy. Instructions said to have it set at 50 amps but got better results at 60-70 amps. Do yourself a favour, they are still on ebay.
PostPosted: Wed Sep 09, 2015 11:01 pm
Is that the gun type? If so they are available with free shipping on ebay at the moment.
PostPosted: Thu Sep 10, 2015 11:49 am
They do look pretty bulky, can they get in close enough to spot a Mini seam?
I have a spot welding nozzle on the Kemppi MIG, used with the inbuilt spot timer it is very repeatable. Can plug weld from 1 side without drilling a hole, even upside down, if metal is clean in between the panels.
PostPosted: Thu Sep 10, 2015 12:44 pm
What's the link to that again doc ? I think I might make one too
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Thu Sep 10, 2015 1:10 pm
There are a few styles, buy one that suits your MIG torch. Mine is a Binzel one.
If you can't find one for yours, braze 2 bits of rod to the outside of a stock nozzle.
It helps if your welder has a spot timer, otherwise get practice!
Pics and info-
https://www.google.com.au/webhp?sourcei ... d%20nozzle
[edit] You want about 8-9mm stickout from the welding tip to the end of the 2 prongs.
You push down on the torch to keep it square, then pull da trigger. Set spot timer, or release when it has filled just above flush. Keep the volts and wire speed (=amps) turned up, you probably want around 100A or so.
Last edited by drmini in aust on Thu Sep 10, 2015 7:04 pm, edited 2 times in total.
Users browsing this forum: Bing [Bot] and 85 guests
