It is currently Wed Jun 25, 2025 12:52 pm
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: 1220 auto build
PostPosted: Thu Sep 10, 2015 4:53 pm
Just picked up this little engine which the guy said came out of his mini K , can someone confirm this please?
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Thu Sep 10, 2015 4:59 pm
I can confirm it is not out of a Mini K.
Probably out of a 74/75 Leyland Mini.
PostPosted: Thu Sep 10, 2015 5:06 pm
Thanks Morris , prompt and precise ... Love it .
Could I ask if it is a 1100 engine and whether the gearbox may well be 4 synchro?
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Thu Sep 10, 2015 5:23 pm
It's an 1100, one of the last Australian assembled 1100s.
The box looks like a rod-change, so yes 4 syncro.
PostPosted: Thu Sep 10, 2015 5:28 pm
Merci!
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Mon Sep 28, 2015 6:12 pm
Got the crank back and it ok , no cracks.
Can anyone enlighten me please :
How does one determine how much to shave off the journals (if at all) ?
There is a ridge down the middle journal but the other feel quite smooth apart from surface rust .
Is this factory balanced or are those machine marks from maybe a previous build?
Many thanks : learning as I go :)
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Mon Sep 28, 2015 6:53 pm
Online
Measure the diameter of the main and crankpin journals.
Std sizes (nominal)-
Crankpins 1.625"
Mains 1.750"
Standard regrinds are to std -.010" -.020", .030", or -.040". If a 1098, I'd not grind it more than .020", and make sure they put a nice radius in the corners, as large as possible.
The notches you see in the crank were put there when made, to hold the crank for machining & grinding.
The grind marks on the webs are factory balancing, or have been done since.
The centre main often wears more than the other two.
 Post subject: 1220 auto build
PostPosted: Sun Oct 04, 2015 5:06 pm
So sorry for the modern metric but :
Crankpins 41.1-41.4mm
Mains 44.4
I'll see if I can translate ;)
Update: more consistent readings indicate 41.2 on the crankpins
So I guess this is a standard grind crank yippee . Maybe just 10 thou needed to clean up ?
Or is it possible to run with it ?? Would save a heap of dollars on a grind :p
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Sun Oct 04, 2015 5:47 pm
Online
If you measured accurately it is now more than .003" wear. Original size limits were 1.6254-1.6259" diameter. = 41.28-41.29mm.
At .001" wear, taper or ovality (absolute max) from original size it's no good. I'd get it reground at less than this.
You can't run it like that. A -.010" regrind will clean it up like a new one
PostPosted: Sun Oct 04, 2015 7:58 pm
last grank grind i had done was only $150, so you don't really save much compared to lunching the engine and starting again because you "saved" money on a regrind.
PostPosted: Sun Oct 04, 2015 9:25 pm
Online
I think Spiro ( @ St George Cranks) charges $200 now for a full regrind. It may be cheaper up in cane toad country. :)
PostPosted: Mon Oct 05, 2015 2:33 pm
Ummm nup hence the hesitancy ... Got quoted 300+
I think many shops up here are getting used to mine prices .. :/
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Mon Oct 05, 2015 2:38 pm
Been testing out me new bead blasting cab.
Still tweeting the settings but running AD size at about 80 psi ... Will crank it a little more to see if it changes speed ...
In other head news:
25.4 exhaust
29.2 inlet
It seems both ports have been seated
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Mon Oct 05, 2015 2:40 pm
Let the clambering fun begin !:)
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Mon Oct 05, 2015 6:54 pm
Just watch out for those pink manifold gaskets - they can have asbestos in them
