It is currently Sat Jul 26, 2025 6:17 pm
 Post subject: Fouling Wheel Weights
PostPosted: Tue Sep 29, 2015 10:11 am
Hi all,
I was wondering if anyone has had any issue with the wheels weights slightly catching your front disc caliper? 10" wheels with the 7.5" discs. Is there an easy fix for this? It's happened before to me but I switched the wheels around and they were fine then.
James
PostPosted: Tue Sep 29, 2015 12:59 pm
What weights are they? If stick- on ones, there are or were 2 thicknesses. I used the thin ones.
I run 10x5 Contessas, with 1 row of weights near the middle. I find this gives better balance than playing about with both inner and outer weights. My local tyre man put me onto this. It works for me. :)
PostPosted: Tue Sep 29, 2015 1:25 pm
Yeah maybe mine are the thicker type. These are on my new 6x10 minators I got from Minisport SA who balanced them. I might need to take them to my local tyre shop and get them rebalanced with thin weights
PostPosted: Tue Sep 29, 2015 5:15 pm
Use a better wheel guy. By spinning the tyre around on the rim your guy should be able to reduce the weights to a minimum. Also tell him where you want the weight to go, They can put the weight closer to the inside edge and you should be good.
G
1962 Mini Speed sports sedan
