It is currently Sat Jul 19, 2025 10:06 am
 Post subject: Direct gear change shaft
PostPosted: Wed Oct 07, 2015 5:14 pm
I have the diff housing for an 850 direct gear change and I have removed the remote control shaft.
Is there a spring behind the nylon seat inside the shaft head below, and how do I get the seat out :|
PostPosted: Wed Oct 07, 2015 5:50 pm
Yes there is a spring,
screw a small tap or ezy out or a big self tapper into the cup. Then pull it out.
PostPosted: Wed Oct 07, 2015 6:14 pm
Thanks Kev.
I bent a bit of stiff wire and shoved it in and pulled it out :D
