It is currently Mon Jul 21, 2025 6:47 pm
 Post subject: Brake certification.
PostPosted: Tue Oct 20, 2015 10:18 am
Has anyone in the past been asked by the blue slip man to get brake modifications certified. I am happy to do it and think it is a very good idea, what are the forms and fees associated, does anyone know? apart from the usual blue slip cost, yada yada yada.
I have the Brake assessment manual printed out and will have a read through, has anyone been through this before?
Nick
 Post subject: Re: Brake certification.
PostPosted: Tue Oct 20, 2015 10:40 am
The RMS VSI06 on page 8 and 9 details the modifications that can be done with and without certification. As far as I can tell, as long as the parts used are in the same configuration as an equivalent model (eg. Cooper S discs on an 850) it should be OK without certification.
http://www.rms.nsw.gov.au/documents/roa ... ations.pdf
PostPosted: Tue Oct 20, 2015 10:47 am
I did read that, but seeing as I am on vented 8.4's from mini sport uk, a 78 Leland s would work with with that extract seeing as the 1275 GT's came with 8.4's. But does the disks being vented throw a spanner in the works? I will be talking to the Eng later today to go through a few things, I will make sure to keep all the documentation for those wishing to do it in the future.
Nick
PostPosted: Wed Oct 21, 2015 3:16 pm
yes, according to the above, they were never factory fitment in that configuration.
But they're also aftermarket alloy calipers with a different type of drive flange aren't they?
Or they might be from a Metro, which should be easier, but still needs checking according to the example above
(VT to LC)
PostPosted: Tue Nov 10, 2015 9:40 am
Engineer approved, picked up a weighbridge cert yesterday. blue slip next step, Should be able to help out if anyone needs a "similar car" certification in future.
Nick
