It is currently Sat Jul 19, 2025 6:59 am
PostPosted: Fri Oct 23, 2015 8:05 pm
Bare block, numbers are 9F/5a/Y 50xxx
Bore diameter is 2.78" - looks like original bore diameter with a bit of wear.
Has end caps for the mains.
Thanks in advance for all the "only as much as someone will pay" responses :)
Alex.
PostPosted: Fri Oct 23, 2015 8:14 pm
Its a Cooper S block by the numbers alone (9F/Sa/Y....). Is it for sale?
PostPosted: Fri Oct 23, 2015 8:50 pm
Not really. I'm building an engine for motorsport, but don't need to worry about period correct hardware.. so if this is worth big bucks and a garden variety 1275 block isn't, then it may be worth juggling.
Alex
PostPosted: Fri Oct 23, 2015 9:11 pm
Yes. It will be worth more as a block than a garden variety 1275. They're all awesome, but those are collectible for another reason other than more power.
PostPosted: Fri Oct 23, 2015 10:08 pm
I sold my Mk2S one last year with its 3 caps, for $600. It was +.040" and needed a rebore. Probably worth more now, they are getting rarer.
Std bore non-S 1275 blocks + caps are worth ~$300-450 IMO. At least that's what I have sold some for in the last few years. Auto blocks at the cheaper end. But then you need to drill oilways and fit a pump spacer.
PostPosted: Fri Oct 23, 2015 10:56 pm
I reckon they're worth twice the value of a standard 1100S type block... someone restoring a MK1 with a rooted block will pay well for it.
Users browsing this forum: Bing [Bot] and 73 guests
