It is currently Sat Jul 19, 2025 1:28 pm
PostPosted: Sat Oct 31, 2015 9:43 pm
Went a bit off tangent tonight and worked on getting the roller rockers set up. Still can't get the rollers over the centres of the valve stems. I know Minisport sells a kit for $35...would this be the best way to go or do I go to a nut and bolt place and get some flat washers?
What are your thoughts?
I must also add that this is the most I have typed here for a long time...so glad when study finished...I have more time to play with the mini...go figure that one!
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sun Nov 01, 2015 7:21 am
Give Ash some flowers Nick .
I don't have roller rockers so I don't have much to add on this topic as to the proper way of doing this, but if you can't find a solution that is right, let me know and I can machine you up some custom width spacers if you'd prefer not to have washers stacked together.
PostPosted: Sun Nov 01, 2015 7:35 am
Thanks for the offer 1018! Much appreciated.
I asked the question as I didn't know whether you needed special types of metal for the shims or just ordinary washers.
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sun Nov 01, 2015 7:43 am
The spacers can be made up from mild steel, I'd use black steam pipe of approximately the size needed and just part off in a lathe. Washers are not made with any exact tolerance. Cheers Richard.
PostPosted: Sun Nov 01, 2015 6:10 pm
Oh dear, worry, worry...
HI ROB
I have spacers 1mm and 2mm, not sure what you are trying to do, with 1.3 rockers and a small cam the rockers will not travel very far across the valve. are you trying to get the roller to start in the middle of the valve or reach the centre of the valve at half lift? if you want some spacers yell out and i'll send some.
Graham Russell
PostPosted: Sun Nov 01, 2015 6:18 pm
He is talking about the centering of the valve on roller east/west not north/south if you get what I mean.
PostPosted: Sun Nov 01, 2015 6:27 pm
HI TK
Sorry :oops: should have read the all the posts, you can buy bronze bushes from a bearing place that slide over the rocker shaft, some are the right size some you may have machine down a little :D
Graham Russell
PostPosted: Sun Nov 01, 2015 6:47 pm
I used these. Just search AEG168 and AEG169.
Probably not worth the postage unless your going to buy other stuff.
http://www.minispares.com/product/classic/AEG169.aspx
http://www.minispares.com/product/Classic/AEG168.aspx
http://www.leacyclassics.com/aeg168.html
