It is currently Thu Jul 24, 2025 2:17 pm
 Post subject: Re: RE 266 SS cam
PostPosted: Sun Oct 18, 2015 7:33 pm
Just wondering how this cam compares to a Re13 cam.
I have this fitted to my 1360 engine
Kiwiinwgtn
PostPosted: Sun Oct 18, 2015 9:53 pm
I asked Graham the question, Answer was the RE13 would have more oomph @ 7000.
But the 266SS would have more grunt on the way up.
RE13 is pretty good in a 1360, I ran one (with 1.5 rockers) in mine before I swapped it to the RE282.
PostPosted: Tue Oct 20, 2015 10:37 am
How would you compare the RE282 to the RE13?
PostPosted: Tue Oct 20, 2015 11:06 am
Graham's exact words:
"an RE282 is worth 10HP over an RE13, any day of the week". :wink:
And properly set up, a 282 will pull pretty well with a Weber/Dellorto from 2200rpm, and is on cam by 2800. Then, it gets a second wind @5000 & the tyres break loose. This with 1.5 rockers on a 1360.
PostPosted: Mon Nov 02, 2015 5:32 pm
Can confirm today that my new 1310 build with the 266SS cam pulled 102.5 hp at flywheel, and 97 ft/lb of torque! Pretty stoked with these figures!
PostPosted: Mon Nov 02, 2015 5:39 pm
Dammit! Haven't even played with my re13 cam yet and I am two camshaft a behind the pack already!
Can GR regains his RE13 to the latest and greatest?
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Mon Nov 02, 2015 6:43 pm
Hooroo
If it's had the RE13 grind put onto a std cam, probably yes. But if it's had a few regrinds already, maybe not.
Jprior's cam had some unknown big grind on it (probably 286-296ish), and Graham turned it into an RE266SS.
PostPosted: Mon Nov 02, 2015 7:57 pm
How is the 266ss at idle? Is it the same as the RE13 with that nice lumpy burble?
PostPosted: Mon Nov 02, 2015 8:23 pm
It's a bit less lumpy than an RE13 and gets on cam sooner. So more drivable low down.
Its torque & HP beats an RE13 all the way to 6000+ rpm, the RE13 then just gets ahead at 6500-7000.
PostPosted: Mon Nov 02, 2015 8:51 pm
Hooroo
Yep was a standard 1098 cam so might have some hope yet. I bought the offset woodruff keys you mentioned many moons ago and just hope the bigger starts when I do turn the key eventually. I do Li,e the sound of the re13 idle so might get my pound of flesh out of it before I get a regrind.
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Mon Nov 02, 2015 9:12 pm
It'll regrind fine then
Users browsing this forum: No registered users and 120 guests
