Joined: Sat Nov 19, 2005 1:37 pm Posts: 2495 Location: Vegus, Brisvegus
I could be wrong but I think there were two series of Metro hubs. The later ones used the self contained ball joints and the early ones used ball joints the same as a mini.
The king pin inclination is different to a mini. It is further from vertical so the line between ball joint centres is further outboard where it hits the ground. This reduces the kick back in the steering when wider track wheels are used. Great if you have a mini that needs big flares but you need longer bottom arms to suit.
M
