It is currently Mon Jul 21, 2025 3:33 pm
 Post subject: Hi-Lo rear and plug?
PostPosted: Sun Nov 15, 2015 7:56 pm
Hi, this isn't that important but I thought I would ask nonetheless. I am installing rear hi-los. The instructions say install the plastic plug into the hole in the rear hi-los (which is apparently meant to allow water drainage when installed in the front). However there are no plugs in the box. Have they changed their mind or are these missing? I'm sure otherwise I can find something to plug the 1/2" hole. Thanks. Jon.
 Post subject: Re: Hi-Lo rear and plug?
PostPosted: Mon Nov 16, 2015 8:33 am
i wouldn`t bother with the plug... just copper-coat the thread inside the hi-lo & the bolt & i normally copper-coat the lip of the donut where it meets the hi-lo too
then Bob`s your Aunty :-)
PostPosted: Mon Nov 16, 2015 12:43 pm
Hi Matt,
Can i ask a stupid question. What do you mean cooper-coat?
Cheers jason
PostPosted: Mon Nov 16, 2015 1:07 pm
its a grease.
http://www.halfords.com/motoring/engine ... grease-20g
1993 R32 Nissan Skyline GTR
PostPosted: Mon Nov 16, 2015 1:34 pm
commonly called anti-seize, can pick it up from supercheap/repco, bunnings might even have some
http://www.supercheapauto.com.au/online ... mendations
2015 Ducati 899 Panigale
PostPosted: Mon Nov 16, 2015 1:52 pm
Online
Kopr-Kote (originally sold here by Ampol, then Caltex) is copper and graphite based. Interestingly, it is not recommended for use with aluminium, or zinc. But, we all have done it.
http://xtex.com.au/kopr-kote-anti-seize/
[edit] I have found the nickel based one is better for exhaust applications. eg on a Maniflow LCB Y-piece.
When I used kopr-kote there years ago, I needed the angle grinder to get it off!
Last edited by drmini in aust on Tue Nov 17, 2015 8:16 am, edited 1 time in total.
PostPosted: Mon Nov 16, 2015 4:07 pm
Hi, yes no worries. I used assembly grease/compound to lubricate the thread. I think the plug according to minispares is a small plastic plug in the packet with the rod, however it is slightly too small for the hole and won't stay put. I used some silastic to stick it in place. Thanks all, Jon.
PostPosted: Tue Nov 17, 2015 12:07 am
Thank you guys for your comments about the anti_seize
Users browsing this forum: Bing [Bot], drmini in aust, kirby and 94 guests
