It is currently Thu Jul 24, 2025 1:48 pm
PostPosted: Mon Nov 16, 2015 4:14 pm
Hi, can someone confirm which way the handbrake quadrant goes? This is the problem with making stuff up from scratch with nothing to compare it to. I'm guessing it must be the same as in the photo but am happy to be advised otherwise :D Thanks, Jon.
PostPosted: Mon Nov 16, 2015 4:53 pm
i dont know if it helps but you can just see the cable guide underneath
PostPosted: Mon Nov 16, 2015 5:29 pm
To refer to the first pic, the quadrant needs to be moved from the top of the arm to the bottom.
You will also notice there is a short section and a long section on the quadrant. The short section should be orientated towards the middle of the car, long section towards the outside of the car.
PostPosted: Mon Nov 16, 2015 6:07 pm
Beautiful, thank you nifty64 for going to the trouble of getting the thing up on the jack, and thanks Matt also.. :-)
