It is currently Sat Jul 12, 2025 3:52 pm
PostPosted: Tue Dec 08, 2015 5:35 am
Hello! A friend of mine gave me a 998cc engine block which is re-bore to 040 yesterday! :D
The block is an old 998 Cooper block (Pre A+) and my question is;
This circlip/piston set intend to fit early 998 A+
http://www.minispares.com/product/Class ... 0to%20shop
Does it fit my Pre A+ Cooper stuff?
PostPosted: Tue Dec 08, 2015 7:19 am
Yes it will, as long as your Cooper has 998/1098 rods (not the old clamp bolt 850/997 ones).
Early A+ had the same rods as a 998/1098 A series. Then they changed to interference fit rod, shorter gudgeon pin with no circlips.
Personally, I would buy locally available flat top pistons, either Hypatec or Russell Engineering.
for example-
http://minisport.com.au/998-080-piston- ... op-hypatec
PostPosted: Tue Dec 08, 2015 8:10 am
Grrrreat! :D Thanx for quick reply!
