It is currently Fri Jul 04, 2025 8:06 pm
PostPosted: Sat Dec 12, 2015 6:17 am
So what about these ones from JonSpeed
Price seems OK
http://www.jonspeedracing.co.uk/index.p ... &cID=13895
1970 MK2 Cooper S
PostPosted: Sat Dec 12, 2015 6:34 am
What model Corolla are they off
1970 MK2 Cooper S
PostPosted: Sat Dec 12, 2015 6:39 am
Oh dear, worry, worry...
HI GRUNDYGUY
Johnspeedracing do not sell rockers, :shock:
Graham Russell
PostPosted: Sat Dec 12, 2015 7:11 am
Old RWD pushrod motor Corollas from the 80s- either the 1108? cc or the 1.3L. Were K2 & K3 motors I think.
They used to go for $20 a set at the wreckers- last set I got a few years ago cost me $50. Probably are scarcer & more $$ now.
As I said, there's a lot of work to do them properly, the Mini rocker shaft needs moving back 3.5mm by plugging welding and remachining the posts, or by making new ones from scratch. Do NOT use old alloy 850 ones turned around- they don't hold head stud tension properly.
The rockers need 1 side faced off, then bushed back from 16mm to 9/16" dia to suit a HD thick wall rocker shaft.
There is a thread on this conversion- see viewtopic.php?f=5&t=3829&hilit=1.5+high+lift+rockers
See p4 for my machining procedure.
[edit] I will copy that bit and put in the how-to forum.
Last edited by drmini in aust on Sat Dec 12, 2015 2:51 pm, edited 2 times in total.
PostPosted: Sat Dec 12, 2015 9:03 am
GR wrote:
HI GRUNDYGUY
Graham Russell
Are you sure about this :shock:
1970 MK2 Cooper S
PostPosted: Sat Dec 12, 2015 10:33 am
:D So has anyone got a set of Corolla Rockers to sell
And maybe a set of posts that i can modify or copy to make new ones
I have searched the internet and cant really find anyone selling old corolla engine parts :D
1970 MK2 Cooper S
PostPosted: Sat Dec 12, 2015 11:20 am
Try your local wrecker mate.
If they don't have any, there's a database I think they have listing who's got what.
Last edited by drmini in aust on Sat Dec 12, 2015 2:49 pm, edited 1 time in total.
PostPosted: Sat Dec 12, 2015 12:05 pm
Hi Gundyguy
Yes I am sure try to buy a set :(
Graham Russell
PostPosted: Sat Dec 12, 2015 12:12 pm
GR wrote:
Hi Gundyguy
Graham Russell
So the photo on their website is just that
they dont have any stock
1970 MK2 Cooper S
PostPosted: Sat Dec 12, 2015 2:54 pm
The rockers need 1 side faced off, then bushed back from 16mm to 9/16" dia.
I made my posts from scratch. You can by the material in the correct size. Drill all the holes then cut over size then machine in lathe. You then machine tapers in one go. You also need a mill to mill the tapers. Its a simple machining job with the right gear.
PostPosted: Sat Dec 12, 2015 4:45 pm
I am a Fitter and Turner and have my own workshop full of machinery
So this isn't a problem
I don't want to pull my car apart to get samples of the posts etc
That why I want to go the Corolla route
I have been restoring old Indian Motorcycles for the last 35 years and do all my own engine work including boring Blind End Cylinders, Alloy welding, etc
This is the second mini i have owned
the first one was about 40 years ago when i was a school kid
1970 MK2 Cooper S
PostPosted: Sat Dec 12, 2015 5:34 pm
I will try and find the drawings i did. With the dimensions if you want.
PostPosted: Sat Dec 12, 2015 5:51 pm
Gundy,
I found it's easier to mod original posts, as I said in that thread. I did make about 4 sets of new steel ones, but it took too long to machine. I could only find black bar at work that was oversize, and so I milled it all down at home.
If you could buy steel the right section that would be easy.
Critical thing when making them is the shaft hole is parallel to the base, and in the same correct position on all 4 posts.
[ps. I'm a fitter & machinist too].
[edit] My machining details are now in the how-to forum. Saves wading through that 9 page thread. Thanks Mick!
viewtopic.php?f=25&t=91263&p=990118#p990118
PostPosted: Sat Dec 12, 2015 9:30 pm
Dammit. I forgot to say that it seems the Jonspeed rockers were just a pipe dream... I tried to buy a set - for over a year....
Tuning should always be a compromise between what is possible and what is necessary.
www.calverst.com
PostPosted: Sat Dec 26, 2015 5:14 pm
Did you find your drawings?
1970 MK2 Cooper S
