It is currently Fri Jul 18, 2025 2:16 pm
 Post subject: Vacuum Advance
PostPosted: Wed Jul 07, 2004 5:04 pm
The vacuum advance on my distributor is punctured. This is letting in air for the dizzy?? or so i am told.
something like that.
Is it worth spending 60 bux for a new one? While its on the dyno, this is what he found and he said to get back to him as he can do more tuning once its fitted.
Let me know.
WIll.
PostPosted: Wed Jul 07, 2004 6:13 pm
well if theres not as much vacuum occuring then you probably wont be getting as much advance......you might get more power at higher revs if you get it fixed dude
PostPosted: Wed Jul 07, 2004 7:11 pm
The vac advance thingy only works at part throttle. It's an economy device, nothing more.
At the risk of getting flamed, I will state: "real performance engines don't need vac advance to get power".
examples:
Morris Cooper S
99% of real race Minis
Fiat twin cams
Alfa twin cams
etc etc.
I have now donned my asbestos suit, so flame away! :lol:
PostPosted: Wed Jul 07, 2004 7:18 pm
Correct again My Alfa 75 2.0 Twinspark. Two Dizzies Two Coils and ten Leads the Dizzies do not have Vac Dizzies.
Also less pipes in the engine bay
PostPosted: Wed Jul 07, 2004 7:34 pm
well there you go! i always thought it was used to advance the timing at higher revs and lotsa throttle.....once again i am learning from the master
PostPosted: Wed Jul 07, 2004 7:39 pm
ive got a vacume dizzy, came off my 998 clubby , its like brand new, only done about 5,000 kms.. i paid $240 for it, ill sell it to you for $100
its perfect, still looks like new :wink:
GTi Turbo'd mini, abused daily
PostPosted: Wed Jul 07, 2004 8:10 pm
Well its back from the dyno. He replaced the vac advance on it with a reconditioned one... 60 bux.
Runs so much better... made the world of differece.
Will post up the "bragging rights" when i go back there to pick up the printout. Left it behind :x
PostPosted: Fri Jul 09, 2004 5:32 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
mechanical advance is beter if i'm not mistaken
makka
PostPosted: Fri Jul 09, 2004 7:11 pm
All Minis have 20-30* mechanical (centrifugal) advance at crank, even if the vac advance is not working..... 8)
Users browsing this forum: No registered users and 118 guests
