It is currently Fri Jul 18, 2025 10:57 pm
PostPosted: Mon Jan 18, 2016 7:01 pm
hi guys as I'm not really mechanical minded is this a good buy from ebay for a exchange unit or should I just try and rebuild the one I have?
is much in it?
http://www.ebay.com.au/itm/Mini-Leyland ... Swa-dWmezt
PostPosted: Mon Jan 18, 2016 7:09 pm
4. Objectionable comments about a business or company, whether it be true or not, are not allowed.
Unfortunately I'm not allowed to answer your question.
PostPosted: Mon Jan 18, 2016 8:37 pm
horns of a dilemma ?
65 panel van Sprog
73 panel van Iggy
PostPosted: Mon Jan 18, 2016 9:55 pm
$495 ??!!!!?????!!!!!!!111
jeebus that's a lot
PostPosted: Tue Jan 19, 2016 8:28 am
If its for the Clubman GT then it isn't the right one.
The GT uses the remote type gear change not the rod change type.
RonR
68 build Mk1 Cooper S
PostPosted: Tue Jan 19, 2016 1:53 pm
RonR
I think his car is a 76 Leyland S.
is much in it?
The main parts that wear are the rod eye extension, slot on the side and the ball on the bottom of the gear lever. Is it jumping out of gear? Rattling? or Sloppy?
My car was doing all 3 and I just fitted a quick shift. All issues now fixed. Some good info here - http://www.moke.com.au/in-the-garage/re ... gearchange
PostPosted: Tue Jan 19, 2016 3:00 pm
You can via a PM. :wink:
PostPosted: Tue Jan 19, 2016 3:15 pm
I have read comments about there motors some are good some are bad
All there parts are well overpriced anyway
I'll check my mini out later and see of its grown a Mercedes badge on it somewhere before I pay them prices on things reco'ed or not
PostPosted: Tue Jan 19, 2016 4:51 pm
I can also answer with sarcasm. :mrgreen:
PostPosted: Tue Jan 19, 2016 5:40 pm
good wit is nicer than bad sarcasm
65 panel van Sprog
73 panel van Iggy
PostPosted: Tue Jan 19, 2016 6:34 pm
thanks Guys I think I get the point :)
I don't paying a little more if I know I'm getting something worth getting.
thanks to all who sent me Private Messages I will give it ago myself.
PostPosted: Tue Jan 19, 2016 8:47 pm
The only thing I know you cant get is the rubber boot that goes on the end of the box where the rod comes out its in the mini king parts book john at mko says you can use some other rubber boot off a different part but
I grabbed a couple of his decent ones off the second hand stock he had in a pallet cage after one of the mitg runs when he was still at narellen
He still has the pallet with them at mulgrave
The ebay ad pic has no rubber boot on there ones
PostPosted: Tue Jan 19, 2016 10:58 pm
Type in "leyland mini rod box shifter units for sale" and see whether that is a better place to get what you are looking for. Just a thought.
PostPosted: Thu Jan 21, 2016 9:12 am
Or a post in the "wanted" section.
PostPosted: Thu Jan 21, 2016 9:18 am
I have three spares so im going to give it ago myself cheers
