It is currently Fri Jun 27, 2025 2:15 am
PostPosted: Sun Jan 31, 2016 10:08 pm
I know there was some discussion on this in the last couple of days, but I want to approach this from a clean slate.
I'm building a race engine - 1275, reasonable cam. Looking at 7500RPM limit.
Assuming I have no distributor at all right now, what is the best option for long term reliable electronic ignition?
I would prefer distributorless (coil over plug or similar), but there don't seem to be a lot of options in this regard for the A series.
The stealth box looks pretty good, but I'm not entirely comfortable buying an electronic module as well as a distributor, plus the stealth box.
Thanks guys
PostPosted: Sun Jan 31, 2016 10:22 pm
If your handy with a spanner then Megajolt would be the way to go.
viewtopic.php?f=25&t=56242
AKA - GTOGREEN1969
PostPosted: Mon Feb 01, 2016 8:28 am
Give Ash some flowers Nick .
+1 megajolt
PostPosted: Mon Feb 01, 2016 5:17 pm
Nobody used no-diz pro? Seems to be simpler.
PostPosted: Mon Feb 01, 2016 5:47 pm
Any old dizzy (locked advance) + module + stealth box.Buying a new Chinese dizzy is a waste of $$.
I once bought a new dizzy with Pertronix II module, the advance curve was rubbish.
PostPosted: Mon Feb 01, 2016 10:23 pm
MegaJolt. As 1018cc says... If I could fit it (thankfully with help from Nick!), then anyone can! And it doesn't have to be any real difference in price to the other options, if you don't currently have anything... Certainly, for the performance/flexibility/reliability, I wouldn't have anything else. I can throw a 0.040" spark through anything! Only trouble is when you short yourself out with it when you're using a Gunsons Colourtune... Does sting for a good while.
PostPosted: Tue Feb 02, 2016 5:39 pm
One word - Scorcher - fit and forget.....
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Wed Feb 03, 2016 12:26 am
I made a table to summarise what I think I know now. The table code for the forum software doesn't work, so I screenshotted it. ugh.
Still keen for more feedback. Thanks :)
PostPosted: Wed Feb 03, 2016 8:27 am
Stealth box + electronic module = under $300. Pulsar dizzy $100 which is what I sold my last one for.
PostPosted: Fri Feb 05, 2016 5:33 am
I installed a 123 dizzy into mine. You get what you pay for.
Fully electronic, one moving parts. 15 minute set up, lest than 5 minutes to tweak. It has 16 preset curves designed for a mini that covers the majority of engines.
I haven't looked back and I'm very pleased with it. I'll be buying another for the project when the time comes.
PostPosted: Fri Feb 05, 2016 1:16 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
I still got my old Aldon just found it with some other bits of the old 1380
