simo74 wrote:
Hobson seem to remember you had a couple of minor teething issues when you fitted them did you get them all sorted and would you recommend them ?
Sorry for the thread hijack, but yes I did, it was bugging me for a quite a while, but with the car off the road while getting work done, and Eng. certs and the like I wasn't to concerned. I knew I needed to have a look at it, last resort being to return to the stock ones.
At the end of last year they released an adjustment guide, worked a treat. I still have to fiddle with on of the sides but its only 2-4mm as opposed to 12-14!, much happy. Note that I had to move my canister whosa wats-it (pretty sure I said that on my thread).
In terms of my opinion of them, I haven't had to use them for any major work yet, not that I have had the time. I do believe they were some of the earlier ones and the design has been slightly refined. But in the 2 or 3 things i did under the low bonnet, one of which was putting the hinges in I smacked my head at least once every time
. They could be a little meatier but I don't think they are meant for vigorous use, like most things look after them and after you. ( I Like them a lot in case that wasn't clear)
I will be sending before and after photos to minivation at their request for the adjustment guide. Note also if you are in Brissy, one of them might be moving over here in the not to distant future, don't tell them I told you I don't want to jinx it (touch wood) all goes to plan.
Edit - If you were up in NSW I would to my best to get to a meet so you could look. (NSW peoples feel free to pester me to come if you want to have a look)
