It is currently Sun Jun 22, 2025 1:24 pm
Post new topic Reply to topic  [ 221 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 15  Next
PostPosted: Wed Jan 06, 2016 4:01 pm
After looking at it again last night I think I can make it work by changing one end of the hose to a banjo fitting and mounting the top end to the subframe where it comes out from the tower. (Near the engine mount) then adjust the steel tubing to suit.
Website: http://www.dutchysmini.com/
Facebook page: https://www.facebook.com/Dutchysmini/
Previously owned the Red VTEC Mini (B16A)
Project currently on the go:
1961 Morris mini
Engine conversion - WRX EJ255
PostPosted: Thu Jan 07, 2016 10:56 pm
Leaving the brakes till the engine is back in so I moved over to the clutch master cylinder.
Straight out of a civic. I made a 38mm high mount which came up quite well. A coat of paint makes it even better.
The pedal seems fits well and doesn't seem to over throw either. It will be another one of those thing to be tested when it is running.
1961 Morris mini
PostPosted: Fri Jan 08, 2016 8:08 am
16sth wrote:
howey wrote:
16sth wrote:
I'm pretty sure brake pipes in Aus still need to be bundy tube, not copper.
Potato, potato. (That saying doesn't really translate into the written word!) I meant brake pipe (whatever is legal. I blame the cat for walking over the keyboard. She's a great speller.)
No it doesn't, I read it as potato potato as opposed to potato potarto, < even that doesn't help.
Doing great work, liking the red much better, suits the Honda engines well I think. Keep it up and she will be driving in no time.
Nick
PostPosted: Wed Jan 13, 2016 7:18 am
Yep. The red is much better. Goes faster too apparently.
1961 Morris mini
PostPosted: Wed Jan 13, 2016 9:26 am
When you painted the rocker cover did you mask the letters or paint thrm and back sand it?
Did you bake the cover to cure the paint?
PostPosted: Wed Jan 13, 2016 9:10 pm
I masked up the holes and painted over the letters. I then left it for 7 days in a hot shed while I was on holidays. When I came back I used a sharp blade to scrape the paint of the letters then used a sanding block with 400 sandpaper. Pretty easy. Just don't use wet and dry as the dirty water from sanding goes into the paint and can't be cleaned due to the texture. Just do it dry and blow the dust off with a compressor.
1961 Morris mini
PostPosted: Fri Jan 29, 2016 7:01 am
Some updates. Clutch line done. Relatively simple in the end
Also did the gear linkages. Still need to be painted though.
1961 Morris mini
PostPosted: Fri Feb 12, 2016 5:19 pm
Custom radiator done and mounted in.
Before you ask, The yellow rocker cover is on to avoid damage to my nice red one.
Engine is back out now for hopefully the last time before the final install.
1961 Morris mini
PostPosted: Fri Feb 12, 2016 6:19 pm
Fancy radiator! Have you changed the size of the core much from a civic one or just moved the inlet and filler?
PostPosted: Fri Feb 12, 2016 6:44 pm
It was a Civic radiator but I cut the tanks off and had new ones added on with new locations for the inlet/outlets.
Core size remains the same
1961 Morris mini
PostPosted: Mon Feb 15, 2016 6:25 pm
Gearbox pulled apart. The diff is completely stuffed.
MFactory 4.0 FD and Helical LSD ordered.
1961 Morris mini
PostPosted: Mon Feb 15, 2016 6:47 pm
owie
Nick
PostPosted: Mon Feb 15, 2016 8:02 pm
Fook! Haven't seen that!
I hope you change all the bearings out whilst you're in there.
As an absolute minimum- you should change the input bearing at the clutch end - it's a known weak point on these boxes.
PostPosted: Mon Feb 15, 2016 8:34 pm
I'll look into this.
1961 Morris mini
PostPosted: Mon Feb 15, 2016 8:35 pm
I am getting new diff bearings with the MFactory LSD
1961 Morris mini
