It is currently Fri Jul 18, 2025 10:54 pm
PostPosted: Tue Mar 01, 2016 4:18 pm
Hey all, I have quite a big cam in my engine, 1340, Dellorto, 286i. The cam was put in when I was doing Hillclimb sprints etc but now I'm doing more runs and cruising. I intend to swap the cam out next time the engine needs attention but for the moment I'm just trying to make it more happy at lower revs.
Question is, if I retard the timing a couple of degrees, will this give me a bit more torque at lower rpm?
PostPosted: Tue Mar 01, 2016 4:25 pm
Advancing cam timing will improve your bottom end, retarding the cam will do the opposite.
1969 Cooper S
PostPosted: Tue Mar 01, 2016 4:32 pm
What he said above. You could also increase rocker clearance a bit, to reduce duration .
I run .022 intake, .024 exhaust on my 282 cam with 1.5 rockers. No they are not noisy.
PostPosted: Tue Mar 01, 2016 4:35 pm
So if I throw in some octane boost and advance a bit and increase Rocker clearance on inlet and exhaust a couple of thou?
PostPosted: Tue Mar 01, 2016 5:11 pm
Don't bother with octane booster don't advance ignition timing. Cam timing and ignition timing are two separate things. Shim as doc suggests.
1969 Cooper S
PostPosted: Tue Mar 01, 2016 5:13 pm
Oops I mean clearance as doc suggests
1969 Cooper S
PostPosted: Tue Mar 01, 2016 10:09 pm
Richard. A stealth black box may help with adjusting timing and improving low torque. You can adjust more accuratley and monitor results. DrMini has some experience with this. I am looking at doing this.
Now with 2 extra ports!
PostPosted: Wed Mar 02, 2016 7:24 am
Just before you do anything, make sure you have a clear idea of cam timing vs ignition timing as suggested (eg by ford boat). Still sounds like they're being talked about interchangeably.
