It is currently Tue Aug 05, 2025 10:26 pm
 Post subject: Running hot
PostPosted: Thu Mar 10, 2016 8:51 am
Could anyone tell me the best way to go about cooling my 1330. Just rebuilt mildly hot engine. It has a four blade fan and a new 2 core radiator. I was thinking a small thermo fan under the left guard to help suck some heat out? Has anyone else had this issue?
 Post subject: Re: Running hot
PostPosted: Thu Mar 10, 2016 9:24 am
Put a Clubby heater core behind the grille. Hook into heater water circuit.
PostPosted: Thu Mar 10, 2016 4:31 pm
First, I would be checking for blocked cores in the radiator. You would be really surprised how much scale comes loose from the engine blocks water jackets after an engine is rebuilt.
1963 Morris 850
PostPosted: Thu Mar 10, 2016 6:26 pm
Already checked that. I was hoping someone with a re13 cam had some insight into this as that is the cam I'm running.
PostPosted: Thu Mar 10, 2016 6:58 pm
I have had 3 motors (1310, 1412, 1360) in my car with no overheating at all. All 3 ran an RE13 cam. However it still has the minimatic heater up front which works like adding a heater core behind the grille. Radiator is stock Mini K/Mini matic/Cooper S 3 core. Reconditioned.
PostPosted: Thu Mar 10, 2016 7:04 pm
I never had a problem with the RE13, even after putting a supercharger on it -
radiator sealed around the cowling so air can't get past without going through the radiator?
ignition retarded?
PostPosted: Thu Mar 10, 2016 7:32 pm
thanks , if I was to put the heater core behind the grill, would it be very noticeable?
PostPosted: Thu Mar 10, 2016 8:19 pm
You can hide a lot of stuff with matt black paint
PostPosted: Thu Mar 10, 2016 8:28 pm
Spray the core a thin coat of black and you won't notice it.
PostPosted: Thu Mar 10, 2016 8:31 pm
Have a look just recently in the "what did you do on your mini today" thread and you'll see JPrior2912 has just installed one and added some pics.
jprior2912 wrote:
Took me most of today, but got to install my heater core/aux radiator (old clubby heater) lots of scratches from reaching down to change the bottom hose for one with a heater take off. but really happy with the results!
PostPosted: Fri Mar 11, 2016 7:34 am
simon k wrote:
ignition retarded?
Very good thing to check before doing anything else :idea:
PostPosted: Fri Mar 11, 2016 8:39 am
Fan the correct way round and a good quality water pump.
"Let us remove your "SHORTS"
PostPosted: Fri Mar 11, 2016 2:03 pm
and a good quality water pump....well at least one with blades not corroded away...
Thermostat???
PostPosted: Fri Mar 11, 2016 2:43 pm
hello i put a second cooler at the front behind the grill. i taped into the heater tap i open it fully for hot days n close it for cooler days.
PostPosted: Fri Mar 11, 2016 2:54 pm
hear is a pic from the top. i used an oil cooler. good luck
Users browsing this forum: Bing [Bot] and 121 guests
