It is currently Sat Jun 21, 2025 1:06 pm
 Post subject: Stainless with Aluminium
PostPosted: Sat Apr 23, 2016 12:44 am
I am making a template for a job using old school tech drawing just to keep me occupied
Ready for laser cutting.Im enjoying this.
Havent done this since high school .
Will stainless be OK with aluminium alloy given water or electrolyte is not present.
I think so.Any ideas.Grade of stainless??
PostPosted: Sat Apr 23, 2016 2:45 am
Next with some help make manifold to put Fazer bike carbs on Elder head.
Bloody cast one would be good but a one off cost would be too much
Webers for now
PostPosted: Sat Apr 23, 2016 8:35 am
They mix stainless with aluminum all the time on modern cars so cant see to much of an issue.
As for manifolds, shouldn't be to hard to make a couple. All you need is flange plates to suit head and carbs and some slightly bent pipe between. All part of the fun!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat Apr 23, 2016 9:32 am
I use stainless screws/bolts in aluminium a lot, I use a bit of never seize on them. Never had a problem.
PostPosted: Sat Apr 23, 2016 6:25 pm
All outboard motors run SS bolts in alloy. To prevent corrosion, OMC used lanolin on assembly.
PostPosted: Sat Apr 23, 2016 6:52 pm
And you hands will end up nice and soft too. :-)
PostPosted: Sun Apr 24, 2016 10:47 am
Hi Guys
Try using Duralac jointing compound
It is chromatic containing, and inhibits electrolytic decomposition between dissimilar metals. It is a single pack air setting product which will prevent anode decomposition even in a harsh marine environment such as stainless fittings on alloy masts and booms on sail boats
Available most marine distributors / ships chandlers that are involved in sailing
It works
Ian
PostPosted: Sun Apr 24, 2016 1:06 pm
Carefull barium chromate isn't good to eat though, try not getting it on your skin in large amounts it can stick around a while. Used in aeroplanes as well as sailing boats. doesn't last forever though, well out on the water that is.
Nick
PostPosted: Sun Apr 24, 2016 5:00 pm
just be careful around sheep
65 panel van Sprog
73 panel van Iggy
PostPosted: Sun Apr 24, 2016 10:33 pm
Thanks guys .The softer my hands the better for me lol.
The middle aged eyesight thing has caused repeat efforts.
I have a computer cad program but it wont resolve less than 1mm
And if you make it do it the job size diminishes
im not buying expensive software.
