It is currently Sat Aug 16, 2025 12:53 pm
 Post subject: MK2 Cooper S Gearbox
PostPosted: Tue Jan 26, 2016 5:40 pm
Whats the best way to identify a MK2 Cooper S gearbox
There is the Casting Number
But there are also other numbers stamped on the left hand side of the front of the gearbox
Does anyone know what these numbers stand for
1970 MK2 Cooper S
 Post subject: Re: MK2 Cooper S Gearbox
PostPosted: Tue Jan 26, 2016 5:55 pm
The numbers that are stamped are the serial number and they will tell what the case originally was fitted to.
It should have something like FAxE 1234 to be a genuine Mk2 case but it might have been rebuilt into a Mini K case with something like 5/12345.
PostPosted: Tue Jan 26, 2016 6:04 pm
Are you looking at this one? http://www.gumtree.com.au/s-ad/morley/e ... 1102238191
PostPosted: Tue Jan 26, 2016 6:13 pm
Here is the gearbox info I have
22G333 4 speed / 3 syncro / B type Remote shift
3 versions of the 22G333 casing.
22G333 X was for the later 970S and does not have the small cut out for crankshaft clearance in the front / radiator corner. Rubber Joints and 3.76 diff
22G333 Y was for very early 1275S's Rubber uni’s up to 9FSAY41233 and 3.44 diff
22G333 Q was the later casing used on most 1275S's Hardy Spicers from 9FSAY41234 and 3.44 diff
Stamped Code 9FA is for the 970S , 12FA is for the 1275S
22G1128 4 Speed / 4 Syncro / Remote shift
Stamped with following code
Mini K = 1234 or 12345 or 5/12345
MK2 S = FAXE 1234
Clubman = 22/1234
Export Moke = 30/1234
Edit - This is a good source of info http://mk1-performance-conversions.co.uk/gearboxes.pdf
PostPosted: Tue Jan 26, 2016 7:43 pm
You should be interested in the gear set as well.
MK2 cooper S gear set varies from mini K set in two ways.
Only the first motion shaft and Cluster gear are different.
The First motion shaft should have 18 teeth to be MK2 cooper S as apposed to the mini K first motion shaft which has 17 teeth.
The MK2 S first motion shaft also has a "S" stamped into the spigot bearing end of the shaft but can't be seen while the box is assembled.
Note: There is also a later first motion shaft with 18 teeth but it takes a larger spigot bearing and requires a different main shaft. This is not a Cooper s part but is sometimes substituted for the original. It is not possible to tell the difference with the box assembled.
The number stamped onto the Cluster gear must be 22G1040 to be MK2 cooper S.
Of course the diff ratio is different too which should be 3.44:1 18 tooth pinion, 62 tooth crown wheel.
Dave
PostPosted: Tue Jan 26, 2016 8:55 pm
I've got some gearboxes with casings without a serial number? But with what would appear to be original cooper s gear sets. Does anyone know where these cases would have come from?
Rod
PostPosted: Tue Jan 26, 2016 9:12 pm
The Mini King
Rod
Most New Gearbox casings did not have a serial number.
I am sure of this, as back in the day Dealers in NSW had to note the serial
number of any gearbox he sold New or second Hand,
and at one time I purchased 700 brand new Gearbox cases at one time
and not one had a serial number ( they are all Gone now ) I also noticed
on some of the ex police cars I purchased did not have serial numbers,
This I found out was because the gearbox case had been replaced
usually because of damage caused by silent Cops
PostPosted: Tue Jan 26, 2016 9:22 pm
Thanks for the info John.
Rod
PostPosted: Tue Jan 26, 2016 9:42 pm
I have a NOS 1128 gearbox with no number stamped. John is correct.
PostPosted: Wed Jan 27, 2016 6:03 am
Yes i was looking at the one on Gumtree and was trying to work out the number that is stamped into the case
1970 MK2 Cooper S
PostPosted: Wed Jan 27, 2016 6:29 am
Going by that number it'd be from a mini K. A Mk2 S would also have Hardy Spicer driveshaft couplings, although these are easily swapped.
That box is missing a couple of the shift linkages that live in the diff housing.
PostPosted: Thu May 12, 2016 5:03 pm
So a MK2 Gearbox should also have the reverse light switch fitted as well?
1970 MK2 Cooper S
PostPosted: Thu May 12, 2016 5:08 pm
I don't think so. It should have the threaded hole there with a blanking bolt but no switch.
viewtopic.php?f=2&t=88074&hilit=reverse+switch
PostPosted: Thu May 12, 2016 5:24 pm
Mine has the switch and the wiring diagram shows the switch fitted
Can anyone provide solid evidence of this matter
1970 MK2 Cooper S
Also an actual photo of what the serial number should look like
1970 MK2 Cooper S
Users browsing this forum: Bill B and 342 guests
