It is currently Sat Jul 19, 2025 2:54 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Feb 03, 2005 3:03 pm
It is pretty low but it is a bit of a lame excuse I mean they should have been able to think of something like driving it up on bricks etc.
I think the rubber cones in the front have compressed. :lol:
Roads need more corners
PostPosted: Thu Feb 03, 2005 3:05 pm
Either way, there are plently of lower cars out there...
 Post subject: Tell us about them....
PostPosted: Thu Feb 03, 2005 6:01 pm
fuzzy-hair-man wrote:
The place I got my tyres, couldn't wheel align my clubman at the same time cause the mini was too low to get the jack under or something like that.
People also DO NOT know how to jack a Mini...thats why you get soccer ball sized humps in the front footwells!!
What we tend to do in the ACT Mini Car Club is spread the word.....don't think we are alone in doing this....all car clubs do....but ONLY if you have and continue to have good experiences with a particular repairer/service provider.
This of course is NO guarranty - as discussed in another thread.
We do tend to recommend the same places though....as long as the good reports keep coming in. The club also has sponsorship arrangements with certain suppliers.
If you find a good place...spread the word and encourage others to go there and SAY that were recommended by another Mini owner.
So it really just amounts to sometimes going out of your way to support a particular business who does the right thing.
Now ...as a for instance, dosen't John Leffler run a suspension business on the southside of Sydney?? He certainly knows Minis.....but, no eye deer what sort of work his shop puts out.
Fuzzy PM sent re Wheel Aligner in Canberra
PostPosted: Thu Feb 03, 2005 8:26 pm
Wombat wrote:
I did it once with adjustable sticks and calk and plumb bobs and level concrete floor etc
then I paid to have it done - Paying is easier :lol:
Easiest way. :wink:
Just make sure the dude knows which is toe-in and which is toe-out. Goodyear Tyre did my Fiat once- gave it 4mm toe-OUT! Rooted the tyres in a couple of weeks.. :cry:
mini is meant to have 1.587mm toe out...
here's the procedure from the manual (apparently no good for a clubman)
1/ with the car on a level floor, turn the wheels to a straight ahead position, pump up the tyres to the recommended pressure, check both tie rods are the same overall length
2/ make a mark on the inside wall of each tyre 184.150mm (7.25") from the wheel centre and 238.76mm (9.4") from the floor surface, in front of the wheel centres. Using a bar type aligning guage, take a measurement between these marks
3/ roll the car forward approx half a wheel turn to bring the marks the same distance from the floor surface, but to the rear of the wheel centres. Again, using the aligning guage take a measurement between the marks. If the alignment is correct, the first measurement should be greater than the second by 1.587mm (0.0625").
4/ if the alignment is incorrect, release the lock-nuts at the tie rod ball joints and turn each tie-rod an equal amount in the required direction and retighten the lock nuts, recheck the alignment
to do it for a clubbie, make sure that there is about 19mm between the tyre and the tie bar at full lock, otherwise it's basically the same
SO THERE! :P :wink:
PostPosted: Thu Feb 03, 2005 9:12 pm
68Delux wrote:
That is not my point! :lol:
I want to know how one used to do it before computers and wheel alignment voodoo magic!
Besides, I am that close to new wheels and tyres, who cares about alignment? I shouldn't be driving my car as is, to quote Gafmo and the Doc :oops:
There were mechanical aligners. I can't remember what they were called but it always seemed to me that to operate it required voodoo and magic. Then of course string and chalk was a good fall back. I recall seeing advertised a device that was driven over and it calculated the toe. It was pommy of course.
Chris
Everything I like is either
PostPosted: Thu Feb 03, 2005 9:24 pm
Some good gear here-
http://www.racerpartswholesale.com/long.htm
I like this one-
http://www.racerpartswholesale.com/long19.htm
and this-
http://www.racerpartswholesale.com/smart1.htm
PostPosted: Fri Feb 04, 2005 7:33 am
Good info Kev, what a good idea those toe plates are. Would work, make them yourself, length to be the diameter of your tyre. Easy. Best idea of the month. Steve
PostPosted: Fri Feb 04, 2005 7:51 am
Cheers for the info. Upon reading the manaul and taking this info into consideration I have decided to call Bob Jane :lol: :wink:
PostPosted: Fri Feb 04, 2005 7:59 am
They need to be concave at the bottom to clear the bulge of the (radial) tyre. 8)
PostPosted: Fri Feb 04, 2005 9:47 am
John Leffler at St george steering is probably the best person to do a wheel alignment on a mini in sydney. He uses all the original equipment, no mumbo jumbo computer stuff. Last time i went to him he just finished doing a wheel alignment on an AC Cobra and was about to start on a Aston Martin. But he wanted to do the mini so the aston had to wait! Great guy.
Aaron
 Post subject: Herne Bay
PostPosted: Fri Feb 04, 2005 7:41 pm
Cheers, Aaron
Now I remember!! Yeah Leffo was one of my hero's when he was racing...he is in Riverwood just up the road from where I did my apprenticehip all those years ago!! 8)
PostPosted: Sat Feb 05, 2005 12:43 am
I went to a great guy at Fairfield called Rex Stafford. Had the old fashioned machines, used to own a mini etc etc. Did an awesome job, with no computer bullshit.
Beware of any place with computers, and a waiting room with a palm tree. They will take your money and stuff your pride and joy. Most of the big chain stores (Bob Jane, Beaurepaires etc) will actually do a wheel alignment on your car even if there's a fault somewhere in the front end!!
The first things this guy did were take it for a test drive with me in the car, then put it up on the hoist to make sure everything was sweet. THEN aligned the wheels, took it for another test drive and checked it all over again. I've motorkhana'ed the car and I'm not real nice to it, but all still seems to be well!!
All this and he still charges less than a chain store who will just let the apprentice loose with a computer aligner which probably desn't fit the 10" or 12" wheels anyway!!!
Just my 2 cents
(any probably still not worth that much!!!!)
Bob Slattery
PostPosted: Sat Feb 05, 2005 6:00 am
I get mine done at Auto City Tyre & Wheel in Station Rd, Seven Hills. The owner (Jim) used to be my neighbour years ago. 8)
PostPosted: Sat Feb 05, 2005 6:21 am
You are kidding....They could not workout a way to get the jack under a Mini... :roll: I would have moved onto the next place also...they probley would have put it under the floor anyway :roll:
Yep I'd pay to get it allighned mate but I know where you are coming from..I watched my old Mec doing this to my Angelo (alfa75) a number of times with his special tool's and it can be done with a piece of string..I'll have to check Morris I think its out also
 Post subject: Howard Revells
PostPosted: Sat Feb 05, 2005 8:07 am
Gaf...there are lots of peeps out there who don't know smick about older cars.....I PMd Arrin and said go to: dah dah!!
HOWARD REVELLS STEERING (now there's an historic speedway name!)
11 Isa Street Fyshwick
see Ian Moon....he knows Minis.
