It is currently Tue Jul 29, 2025 12:26 pm
PostPosted: Mon Dec 27, 2010 8:33 pm
Give Ash some flowers Nick .
Lockie91 wrote:
1018cc wrote:
Lockie, undo the CV nut etc and then pull the drive flange out, you should be able to get to the back of the allen key headed bolts then. Hopefully the drive flange isn't rusted to the bearing race.
and if it is? :oops: I don't think its ever been off from the look of it..
What am I going to have to replace?
If it is rusted on there you will need about 1m worth of chain (links about the dia of a mini wheel stud, two strong washers, two wheel nuts and a sledge hammer. You put the two wheel studs through either end loop of the chain along with the washer's and tighten down with the wheel nuts. Loop the chain around the sledgehammer and swing. If the flange is rusted to the bearing race it will soon be pulled off.
If that happens you will probably need a new drive flange, wheel bearings, grease etc bit it should let you soak the screws with WD40 / innox etc from the back straight into the thread.
PostPosted: Mon Dec 27, 2010 9:05 pm
Impact drivers have "Bits/tips" that fit into them, Phillips screw driver tips/bits are just one of the many types of tips that fit into the end of them... Allen head tips also fit
PostPosted: Mon Dec 27, 2010 9:40 pm
Or fit discs
Simplify and add lightness
PostPosted: Mon Dec 27, 2010 10:39 pm
arh thanks guys, I'll let you know how I go. Hopefully it should come off the proper way :wink:
Yes Joe, I love disc's, wanna hand up your rear ones your not using atm for gratis? :lol:
PostPosted: Mon Dec 27, 2010 11:28 pm
Sure, just need to borrow 1500ish off you to cover the costs then ill let you borrow them for as long as you need them.
PostPosted: Mon Dec 27, 2010 11:47 pm
hehe will you come and install them for me at that price :P :P
