Lockie91 wrote:
1018cc wrote:
Lockie, undo the CV nut etc and then pull the drive flange out, you should be able to get to the back of the allen key headed bolts then. Hopefully the drive flange isn't rusted to the bearing race.
and if it is?
I don't think its ever been off from the look of it..
What am I going to have to replace?
If it is rusted on there you will need about 1m worth of chain (links about the dia of a mini wheel stud, two strong washers, two wheel nuts and a sledge hammer. You put the two wheel studs through either end loop of the chain along with the washer's and tighten down with the wheel nuts. Loop the chain around the sledgehammer and swing. If the flange is rusted to the bearing race it will soon be pulled off.
If that happens you will probably need a new drive flange, wheel bearings, grease etc bit it should let you soak the screws with WD40 / innox etc from the back straight into the thread.
