It is currently Tue Aug 12, 2025 5:29 am
PostPosted: Tue Oct 22, 2013 6:42 pm
cush wrote:
You crazy Matthews must stick together...
http://minisport.com.au/prod593.htm
I'm assuming Matt (Read) your bit replaces the metal part of the above kit?
Sent from my Nexus 7 using Tapatalk
Yes.
Matt's one has the o-ring next to the shaft whereas the other common one has the o-ring next to the casing, meaning it still has a gap to allow the shaft to move.
Having said that, i have one of the common ones in mine and it has not leaked in a year. Only reason i got it was because Matt was out of stock at the time. Then he goes and modifies his design to make it removable. I think next time i change the oil i'll stick one of Matt's in because the current one will probably be leaking by then.
michael
PostPosted: Tue Oct 22, 2013 8:44 pm
So... Where them MiniKing/Miniman contact details at?
PostPosted: Tue Oct 22, 2013 8:47 pm
You can PM `John Smidt' or `TheMiniMan', otherwise look at the list in the how-to forum under Mini Biz.
PostPosted: Tue Oct 22, 2013 8:54 pm
Oh yeah... PM... ha.. It's been a while
PostPosted: Wed Oct 23, 2013 10:45 pm
What was the size socket to use to put the seals in?
I might even make a greasier version of this video..
http://www.youtube.com/watch?v=61FMWca5AM8
PostPosted: Sun Oct 27, 2013 3:21 pm
Three rubber seals out so far.. :)
PostPosted: Sun Jan 12, 2014 4:01 pm
awdmoke wrote:
The hard part is getting all the old ones out.
Indeed it is...
Is there a trick to getting it out? Drill? What kind of bit will I need?
Users browsing this forum: No registered users and 236 guests
