It is currently Sun Jul 27, 2025 8:44 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Jun 25, 2012 9:19 am
So, is this a conversion loom Clubby>roundy that you are adding?
If so wheredidyagetit- Minispares?
I need 1 for da hydro stealth van I'm building. 8)
this is the fella
http://www.minispares.com/product/Class ... |Back%20to
has all the bulb holders with it so you just cut and crimp to your current loom.
Rich
PostPosted: Mon Jul 02, 2012 9:39 am
O.k so I installed my gauge yesterday and all good!! But 2 things...
1/ Might need to get a slighly longer speedo cable as it was a bit tight to connect
2/ The red igniton light did not come on at all where as the other lights on the clock all light up o.k, the ignition clock side was a white cable and then was connected to the white/brown cable from the other side which would have been going to the plug which would have been connected to the 2 clock cluster.
Any ideas guys?
Rich
PostPosted: Sun Jul 15, 2012 12:19 pm
Hey guys,
My mini died on me yesterday and am a bit paranoid if it had to do with the clock I had installed?
Like I said above the ignition light does not come on so would that effect the alternator/battery?
Rich
PostPosted: Sun Jul 15, 2012 3:02 pm
If the ignition light is not in circuit (ie working) your (Lucas) alternator won't charge.
PostPosted: Sun Jul 15, 2012 5:03 pm
The Mini King
Kev Try Linsay Or Someone who has Japanese imports The Japs Made a loom that Simply clips into the original loom I do not currently have one
PostPosted: Sun Jul 15, 2012 7:59 pm
Right so I have put the old clocks back in and everything is working fine inc the ignition light.
What am I missing to make the new clock work? See above to the wiring colors I have matched.
Rich
PostPosted: Mon Jul 16, 2012 8:53 pm
Or you could just connect up the indicator lamp... one side to the switched side of the ignition switch and the other to the alternator. I think it goes to the output side but its the thin wire attached to a terminal marked "ind" on my alternator.
If you can't buy a bespoke loom its easy enough to chase the various wires through and add the required extra length and fittings to connect to the spades on the speedo..
Cheers, Ian
