It is currently Sun Jul 27, 2025 4:57 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Jun 25, 2012 9:19 am
So, is this a conversion loom Clubby>roundy that you are adding?
If so wheredidyagetit- Minispares?
I need 1 for da hydro stealth van I'm building. 8)
this is the fella
http://www.minispares.com/product/Class ... |Back%20to
has all the bulb holders with it so you just cut and crimp to your current loom.
Rich
PostPosted: Mon Jul 02, 2012 9:39 am
O.k so I installed my gauge yesterday and all good!! But 2 things...
1/ Might need to get a slighly longer speedo cable as it was a bit tight to connect
2/ The red igniton light did not come on at all where as the other lights on the clock all light up o.k, the ignition clock side was a white cable and then was connected to the white/brown cable from the other side which would have been going to the plug which would have been connected to the 2 clock cluster.
Any ideas guys?
Rich
PostPosted: Sun Jul 15, 2012 12:19 pm
Hey guys,
My mini died on me yesterday and am a bit paranoid if it had to do with the clock I had installed?
Like I said above the ignition light does not come on so would that effect the alternator/battery?
Rich
PostPosted: Sun Jul 15, 2012 3:02 pm
If the ignition light is not in circuit (ie working) your (Lucas) alternator won't charge.
PostPosted: Sun Jul 15, 2012 5:03 pm
The Mini King
Kev Try Linsay Or Someone who has Japanese imports The Japs Made a loom that Simply clips into the original loom I do not currently have one
PostPosted: Sun Jul 15, 2012 7:59 pm
Right so I have put the old clocks back in and everything is working fine inc the ignition light.
What am I missing to make the new clock work? See above to the wiring colors I have matched.
Rich
PostPosted: Mon Jul 16, 2012 8:53 pm
Or you could just connect up the indicator lamp... one side to the switched side of the ignition switch and the other to the alternator. I think it goes to the output side but its the thin wire attached to a terminal marked "ind" on my alternator.
If you can't buy a bespoke loom its easy enough to chase the various wires through and add the required extra length and fittings to connect to the spades on the speedo..
Cheers, Ian
Users browsing this forum: timmy201 and 85 guests
