It is currently Sat Aug 09, 2025 3:36 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 224, 225, 226, 227, 228, 229, 230 ... 568  Next
PostPosted: Mon Mar 28, 2011 8:36 pm
michaelb wrote:
Did a trial fit of the new alloy radiator onto the project engine. Measured the distance from the thermostat housing to the outside of the radiator and then checked the Cooper S measurement so I can confirm the engine will fit in the car with the Supercharger pulley and the wider alloy radiator.
Looks OK but pretty close fit, about 3mm clearance. :)
So, did you succeed in fitting a harmonic balancer to the pulley, or are you going to fly without one? :shock:
PostPosted: Mon Mar 28, 2011 9:19 pm
Spoke with GR and he thinks should be OK for the use I will be putting the engine to.
Very limited space between radiator support and pulley, not even enough to fit a fan belt, so radiator loosen job to replace and fit a new belt.
I am still confused by this issue as the original pulley was only a tin pulley which has totally rusted
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Mar 28, 2011 9:24 pm
If it was a tin pulley, it's off an 850 or 998, all others 997-998-1098-1275 got a harmonic balancer either 1 or 2 piece.
PostPosted: Tue Mar 29, 2011 7:27 am
Definately was a crappy tin pulley, and I think I have thrown it away as it was so badly rusted. Engine had been reconditioned by a Mini business in Sydney prior to me purchasing the car.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Mar 29, 2011 9:06 am
bingo!
you need a pulley like mine - standard mini pulley, single 4 rib belt :D
 Post subject: Jacking a stuffed roof
PostPosted: Tue Mar 29, 2011 12:57 pm
A big block of snow fell almost 16' from the house roof and stuffed the roof of a 1969 MKII Mini Cooper shell with hydrolastic.
So...yesterday I thought why not try jacking up the roof to see if the rear gutter (had been driven down) and the 4 corners could be brought up to shape so a mini roof could be grafted on (minus the pillars of course).
Was great fun hearing the roof "pop" and I let out a Whoop each time. Neighbors must think I'm nuts....
Long story short, the perimeter will support a graft job and the rear gutter came up with the roof sans any contact with jacking pieces.
Could become part of a '69 Cooper S reshell.[/img]
PostPosted: Tue Mar 29, 2011 2:50 pm
Watched husband take the engine out of the Moke.
Julie.............
PostPosted: Tue Mar 29, 2011 2:53 pm
asked around to try to get quotes etc for engine rebuild
You can't drive your shares on the weekend...
PostPosted: Tue Mar 29, 2011 3:11 pm
Good to see he is wearing a good pair of Wollondilly safety shoes. :wink:
So why is the engine coming out?
Is it dead or we have plans. :)
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Mar 29, 2011 3:19 pm
Safety first as always with Wayne. You should see him dance around when he's welding - still wont put shoes on. :P
Nothing at all wrong with the engine. It has been on loan from Wayne's S for the last couple of years. Time to go back home to the Cooper.
The Moke is getting a bigger motor (stroker) with LSD and a nice new set of wheels and tyres. All completed for Hay of course. :D
Julie.............
PostPosted: Tue Mar 29, 2011 3:32 pm
Ahh! Yes I forgot about Hay.
Good luck.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Mar 29, 2011 9:32 pm
I found the old pulley from the 1275LS motor.
As I said, crappy tin pulley.
Any thing has to be better?
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Mar 29, 2011 9:39 pm
geez Michael that's a good one, the power of my old twin carb 850 ripped all the rivets out of mine. :P
PostPosted: Tue Mar 29, 2011 9:41 pm
Took the battery out to fire up the ride on mower, then reinstalled battery :wink:
PostPosted: Tue Mar 29, 2011 9:53 pm
Got mine registered again today Woohoo :D :D :D
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
