It is currently Sat Aug 09, 2025 7:48 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 227, 228, 229, 230, 231, 232, 233 ... 568  Next
PostPosted: Wed Apr 06, 2011 9:54 am
my saga of my mini having the sh!ts with me is continuing
on Sunday I took my alternator off to find the mouse hiding in it (squeaks)
on Monday I reconditioned the alternator by cleaning the slip rings, fitting new bearings, sandblasting and iriditing the body... looks nice
Monday night I went to put it back on, and my fanbelt split, and I also discovered that the blower pulley has been contacting the bracket I made for my hydro pipes
Yesterday I hunted around (5 shops!) and bought a new fan belt (turns out my belt only suits a Chrysler Neon/PT Cruiser - ewww!)
Last night I removed the blower and discovered that
1. The carb side manifold had been grinding on the lip for the speedo cutout, so I need to weld it up again and bend the lip out of the way
2. The bottom mount bolt for the blower was missing
3. The bottom front radiator shroud screw was also missing!
4. One of my belt idlers is sounding quite second-hand
And I used those little tiny cutting disks on my dremel to cut a chunk out of the hydro pipe bracket
PostPosted: Wed Apr 06, 2011 10:28 am
Those little disks dont seem to last very long.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Apr 06, 2011 10:43 am
Give Ash some flowers Nick .
I buy reinforced discs for mine and they last heaps longer. You can tell because you only get 5 in pack compared with 25 :lol:
PostPosted: Wed Apr 06, 2011 12:19 pm
Let me know simon if you'd like a genuine chrysler belt for your mini!
Has to be some advantage of working for a chrysler dealer!
Jack of all trades, master of none......
PostPosted: Wed Apr 06, 2011 1:17 pm
Going to fit my 5 speed gearbox, and then fit the raditor to the mini, and then put it into the subframe,
PostPosted: Wed Apr 06, 2011 6:47 pm
I had a few spare hours on my lunch break today, so I:
Threw some subframes in the moke
Did the brake lines
Ran fuel lines
Did the drive shafts
Put the disc brakes on the front.
Sorted rear brakes
Bolted on rear adjustable camber brackets
Changed all the donuts and installed (read modified to fit) hi-los
Put new shocks on each corner
Sorted adj. suspension for the front
Did some wiring
Changed bulbs for the speedo
Did new leads/plugs for the clubman, gave it a tune. Millionaire 998 ran like a pig again within 10minutes - awesome.
Installed new master cylinders
You're so square
Baby I don't care
PostPosted: Wed Apr 06, 2011 7:44 pm
What a productive lunch break.
That list would keep me going for weeks. :?
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Apr 06, 2011 7:59 pm
What can I say, I guess I work quickly :)
I stopped for tea midway, which gave me the boost I needed
You're so square
Baby I don't care
PostPosted: Wed Apr 06, 2011 8:01 pm
You stopped for a tea-break during a lunch break? :lol: :lol:
PostPosted: Wed Apr 06, 2011 8:09 pm
Milatsmadmini
Wow Adam man, was that when i was with you or before hand? :lol:
PostPosted: Wed Apr 06, 2011 9:26 pm
The parts I ordered yesterday at 2pm turned up in the mail this afternoon at 2pm - Minisport my hat is off to you!!
Still no shocks though...grrrr
Rob Forsyth
Miniot!!
PostPosted: Fri Apr 08, 2011 8:07 pm
Charged the battery. Wash and polish. Hopefully get her out for a spin tomorrow. First time in 3 months
ook!
69 mini k
PostPosted: Fri Apr 08, 2011 9:20 pm
Whats iriditing :?
PostPosted: Sat Apr 09, 2011 11:51 am
No goodies arrived this week. :( so looks like the box will have to wait longer... :cry:
PostPosted: Sat Apr 09, 2011 4:33 pm
Delivered the project body over to the paint shop in the Shire.
Finally!
Now to concentrate on the engine gearbox and subframes
1969 Cooper "S"
1967 Mini Deluxe
