It is currently Sat Jul 19, 2025 6:53 am
PostPosted: Tue Jun 10, 2008 12:58 pm
Milatsmadmini
can these 2 be mated to work effectively, or am i just wasting my time?
pics!
Matt
PostPosted: Tue Jun 10, 2008 1:03 pm
It ain't rocket science to connect a factory tacho.
There is a wire or two needed for the backlight (take off from existing), there is a wire that goes to the coil and there is another wire that goes somewhere else (won't say yet, I'm not 100% sure).
:D
PostPosted: Tue Jun 10, 2008 1:19 pm
yes, had the same setup in my van, just a bit of wiring and all will be good
1962 850,Frog
PostPosted: Tue Jun 10, 2008 1:44 pm
yea easy because the 3 gauge cluster is a 2 gauge with a clock or tacho screwed on the end.
you can swap the printed circuit board for one from a 3 gauge cluster, or you can wire the tacho up seperately.
PostPosted: Tue Jun 10, 2008 2:09 pm
http://www.ausmini.com/forums/viewtopic.php?t=34963
PostPosted: Tue Jun 10, 2008 5:04 pm
wont you also need 3 guage bracketry?
blokeinamoke wrote:
PostPosted: Tue Jun 10, 2008 6:18 pm
The Forkmeister
Matt, you will need the 3 guage bracket, just give John at the mini king a call,(0246481233), he has a few of those hanging around.
Cheers Gerg
May the fork be with you.
