It is currently Thu Aug 07, 2025 6:36 pm
 Post subject: Temp sender adaptor
PostPosted: Fri Jun 24, 2011 7:37 pm
Changing my mechanical temp gauge to electrical 1275 block.
I had a look around struggling to find an adaptor from block to suit my electric sender.
Part : SMITT6811-01 1/8"
I could probably cut a thread at work into the smaller adaptor bush in pic to fit the sender but is there a single bush that would do the trick from the block to sender?
PostPosted: Fri Jun 24, 2011 7:47 pm
If you post me the sender I will make you one.
The thread in the head is 5/8-18 UNF.
PostPosted: Fri Jun 24, 2011 7:56 pm
Mods rock!
The thread on his new sender is 1/8" 27 NPT.
PostPosted: Fri Jun 24, 2011 8:00 pm
I said before- (I have that tap, give me dimensions needed or a sketch and I will make and post).
[edit] I can make from a 3/8 or 1/2 BSP brass hex plug, dimensions not needed now.
Last edited by drmini in aust on Fri Jun 24, 2011 8:06 pm, edited 2 times in total.
PostPosted: Fri Jun 24, 2011 8:02 pm
If you can I would like 2 of them as well.
Cheers Pete
PostPosted: Fri Jun 24, 2011 8:05 pm
I'll knock some up early next week.
PostPosted: Fri Jun 24, 2011 8:34 pm
Thanks Doc. Pm sent
Solid work GT
Cheers. Sean
PostPosted: Mon Jun 27, 2011 9:15 pm
Guys I've got the 3 hex brass plugs, will machine them on Thursday (aka Mini machine shop day). :P
PostPosted: Tue Jun 28, 2011 7:34 pm
I will take one also Doc if there are any left... :D
Rob Forsyth
Miniot!!
PostPosted: Tue Jun 28, 2011 7:53 pm
No problem.
PostPosted: Wed Jun 29, 2011 10:05 am
Is 5/8-18 UNF standard bolt size/thread? - need a blanking bit for my extra thermostat hole
David L
PostPosted: Wed Jun 29, 2011 10:24 am
Mods rock!
Yes. It is just 'ordinary' 5/8" UNF. the '-18' bit is the threads per inch. If your fitting a steel bolt, grease it to slow the rusting / corrosion.
PostPosted: Fri Jul 01, 2011 5:00 pm
OK guys these 4 are in the mail, if anybody else wants one made too, $12 ea including post.
PostPosted: Mon Jul 04, 2011 10:21 pm
will send you a pm when i get home doc, im in need of an adapter of slightly different nature
