It is currently Mon Aug 18, 2025 12:10 pm
 Post subject: Alternator Check
PostPosted: Tue Jul 28, 2009 7:31 pm
Guys I had my alternator fail on me. The warning light gradually got darker and darker over a few weeks. It has since died completely. Ive also thrown in a mitsubishi brand from a ford laser and a bosch from an ea falcon since and have had the same problem of no charge. They were wired up correctly. Now before I swap for a third one, is there anything I should check on the car first that could be failing or has pick and payless just sold me a couple of of duds?
So... I'm Seifer
PostPosted: Tue Jul 28, 2009 7:37 pm
Check the light globe.
PostPosted: Tue Jul 28, 2009 7:59 pm
Alts dont like being shelved for a long time, unbolt a freshie an use that
PostPosted: Tue Jul 28, 2009 8:03 pm
Tomboss Breweros
Top tip,
Easy check for this is to disconnect the small wire to the back of the alternator, poke a test light into it and turn on the ignition, dash light should come on.
Is the connection at the start solenoid good?
kimini wrote:
Jimmyinamini wrote:
PostPosted: Tue Jul 28, 2009 9:12 pm
yeah the connections have been cleaned just in case and im changing batteries every couple of days (recharging the spare obviously) so its not just the globe.
So... I'm Seifer
