It is currently Mon Aug 18, 2025 8:50 pm
 Post subject: Alternator Check
PostPosted: Tue Jul 28, 2009 7:31 pm
Guys I had my alternator fail on me. The warning light gradually got darker and darker over a few weeks. It has since died completely. Ive also thrown in a mitsubishi brand from a ford laser and a bosch from an ea falcon since and have had the same problem of no charge. They were wired up correctly. Now before I swap for a third one, is there anything I should check on the car first that could be failing or has pick and payless just sold me a couple of of duds?
So... I'm Seifer
PostPosted: Tue Jul 28, 2009 7:37 pm
Check the light globe.
PostPosted: Tue Jul 28, 2009 7:59 pm
Alts dont like being shelved for a long time, unbolt a freshie an use that
PostPosted: Tue Jul 28, 2009 8:03 pm
Tomboss Breweros
Top tip,
Easy check for this is to disconnect the small wire to the back of the alternator, poke a test light into it and turn on the ignition, dash light should come on.
Is the connection at the start solenoid good?
kimini wrote:
Jimmyinamini wrote:
PostPosted: Tue Jul 28, 2009 9:12 pm
yeah the connections have been cleaned just in case and im changing batteries every couple of days (recharging the spare obviously) so its not just the globe.
So... I'm Seifer
Users browsing this forum: drmini in aust and 292 guests
