It is currently Sun Jul 27, 2025 11:02 pm
 Post subject: Water Pump
PostPosted: Mon Apr 04, 2005 11:20 pm
When is it not working.
I have changed the thermostat (74), Flushed the System (including the Heater), Ensured no Airpockets in the head.
Still heats to half realy quickly and goes to High and stays thier...
Other than that could it be the bottom radiator hose contracting :roll:
I have also done the Bushies Compretion test all fine thier also
PostPosted: Mon Apr 04, 2005 11:21 pm
Checked the timing? Might be retarded...:wink:
PostPosted: Mon Apr 04, 2005 11:25 pm
We did that :?
PostPosted: Mon Apr 04, 2005 11:41 pm
How worn is the pump likely to be? I have heard of some pumps cavitating when worn. When was the last time you spun it - was the bearing OK? (usually do this off the car however)
The hi-flow pumps are about $70 at Karcraft I think.
Other than that, even though you flushed the rad, is it time to consider pulling it out for a service?
KB
PostPosted: Tue Apr 05, 2005 6:38 am
I hate pulling the Rad out but I guess I could Marcia (The Donner) hers and see how the goes. I may as well pull the water pump off as well then :roll:
PostPosted: Tue Apr 05, 2005 8:54 am
whats your rad like? how old is it?
Might need a flush out of the car, or top and bottom tanks off for a core clean.
My clubby rad looks like it was replaced recently....nice and new....but I am taking it to a rad place for a pressure flush. :P
PostPosted: Tue Apr 05, 2005 9:01 am
I had similar overheating problems in my deluxe, checked everything, flushed system out a lot, cores all looked clean but nothing worked.
In the end I took it to my local radiator works and he took the tanks off for a core clean.
About 40% of the cores were completely blocked, you just couldn't tell with the tank on!
Recored rad & now it's sweet as.
Cheers & good luck
Matt
PostPosted: Tue Apr 05, 2005 9:45 am
Matt, I agree 110%. I have seen guys do this on a rad, and it's amazing how much sh!t comes out.
Jim, I am getting mine done soon....lets take both there and push for a discount! :D
PostPosted: Tue Apr 05, 2005 10:53 am
A lot of my overheating issues were due to the temp guage being out :oops:.
New radiator, hoses and water pump before I worked that out.
PostPosted: Tue Apr 05, 2005 11:59 am
that would anoy me redfive hate it when things like that happen.
PostPosted: Tue Apr 05, 2005 5:25 pm
We'll the Rad is around 2 - 3 years 2 core special from Karcraft
How Much does it cost..(only asking as they will be shut by now :?
But I'll call around tomorrow as I have the day off, Wify is going for her First Little Gafmo check 8)
I was hoping to pop into Karcraft tomorrow for some bits for Marcia While we were out..Hopeing Sue will be in a good mood and I can spend a few dollars :lol:
Anyway I degre's I also have two other rad's and a few Heater rads + plus a oil cooler...Bulk job may work..(srug of the shoulders)
PostPosted: Tue Apr 05, 2005 10:27 pm
You did run plain water in it for quite a while, the rad core might be coated in crud...
What pump is it? I've seen them with cast iron impellers (good), plastic impellers (??), & bent tin impellers (crap)..!
PostPosted: Tue Apr 05, 2005 10:51 pm
Mate, no Idea what the Pump Looks Like.....Can't even say I even had a look at it what we rebuilt the motor.. :?
Intentiion tomorrow..Fine someone to do over one of my spares and put it in...Then redo Morris's old one and put it into Marcia :idea:
If all goes well I will not touch it..But if it fails it's the pump newbie
Sue's has said the Fan belt is slipping..but I have driven Morris in the last couple of weeks and have not notice to much skwealling
PostPosted: Wed Apr 06, 2005 3:44 pm
$95 to rip the tanks off and rod them.
$40 for Heater cores and $30 for a Oil cooler to be cemicaly diped
And no discount if all together and a total 3 Radiators
I thought it was goi9ng to cheaper than that :x
PostPosted: Wed Apr 06, 2005 3:51 pm
where from?.... I was expecting $90 for the rad clean....
