It is currently Sat Aug 09, 2025 7:40 pm
 Post subject: smiths tacho wiring
PostPosted: Thu Apr 01, 2010 7:33 pm
Hi, i took off my smiths tacho to relocate it and cant get it working again.
it is one of those current sensing types.
the loop wire sits in a plastic block, does this just need to be clamped down close to the sensor?
it has power and earthed, its just not picking up the signal.
i have tested the wire and has 0 ohms
any ideas? or pics of the rear of a tacho?
cheers ryan
1971 mk2 police cooper s
1988 rover mayfair modified!!
PostPosted: Thu Apr 01, 2010 7:36 pm
Search is your friend? :wink:
2nd page in chat, seems like some good info there
http://www.ausmini.com/forums/viewtopic.php?t=62137
hth cheers
Jacob
PostPosted: Thu Apr 01, 2010 7:40 pm
cheers,
im having problems with the search on ausmini.
just started this last week, but ill follow the link
PostPosted: Thu Apr 01, 2010 8:25 pm
In a similar vein, what have I done wrong if my tacho needle rises and falls with the indicator flashes?
M
PostPosted: Thu Apr 01, 2010 9:20 pm
normally that would mean a bad earth mokesta,
i don't know how but i think my tacho is stuffed, anyone want to sell one?
PostPosted: Thu Apr 01, 2010 9:42 pm
Try looping the sensing wire from your coil in the opposite direction through the pickup.
If you've connected +ve and -ve the right way around, this is the other thing to check.
PostPosted: Fri Apr 02, 2010 2:22 pm
i had that issue check that the cable from the coil to dist hasnt been swapped around. i swapped mine and worked great!
PostPosted: Fri Apr 02, 2010 6:29 pm
yep got it working, wires the wrong way around.
thanks for your help, i'll take some pics after the weekend and post them!
