It is currently Sun Aug 17, 2025 6:09 pm
PostPosted: Wed May 05, 2010 1:01 pm
Hi All.
What are the correct screws to use to hold the MKI steering column shroud on? Where can I get some?
My very old column was just held on by a couple of self tappers at the top, and insulation tape at the bottom! So I would like to get it right this time.
PostPosted: Wed May 05, 2010 1:16 pm
A couple of self tappers. Little short ones with just the right diameter. I'm not sure but they may have been black originally, all the ones I ever see are rusty.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Wed May 05, 2010 1:26 pm
Thanks for your help Timbo, I wasn't sure if the little ones were a machine thread or self tapper. I'll see if autobarn etc have any black ones.
Jim
PostPosted: Wed May 05, 2010 1:32 pm
Had a look in the parts manual, the two numbers are different but seem to work out to be something like 6 gauge self tappers with a pozidrive pan head and ether 1/4" long or .325", and zinc plated. Black ones probably look better though.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Wed May 05, 2010 1:36 pm
Thanks Tim. I'll check out Autobarn or Bunnings... if I can't get black, I'll use a indelible black marker pen! :lol:
Jim
PostPosted: Wed May 05, 2010 1:42 pm
The correct self tappers are still available. Last time I dropped into The Mini King he had two wooden boxes full of the longer and shorter of the small self tappers. I grabbed a metric handful of both. I notice you're very nearby, if you're really keen to grab a couple drop me a PM.
PostPosted: Wed May 05, 2010 1:56 pm
you can't ask for "correct" then go to autobarn or bunnings!! nooo!!! wrong!!! bad!!!
PostPosted: Wed May 05, 2010 2:08 pm
Sorry, my bad! :oops:
Jim
edit: removed PM reference, wrong person
PostPosted: Wed May 05, 2010 8:31 pm
The Mini King
From Memory, The Top Screw was Chrome Plated and The Bottom Screw Zinc Plated The Top Screw Usually oxidized Before The Bottom Screw, This Is From Memory Only
PostPosted: Thu May 06, 2010 6:30 am
On UK built cars, they are chrome finished and Philips head.
Regards
Al
