Wombat wrote:
I haven't checked the other side - but do you normally replace both as a pair or only if damaged?
Complete CV joints either outright or exchange are not very expensive these days, although I have a strong preferance for new joints. Some of the re-built ones are not much better than the ones you take out.
Generally, I would only replace the one side if that is knackered, although, if I'm doing a ground up resto, then I do
everything so it all starts off on the same foot. Depends too on how much $$$$ you wish to invest in your project and how much use it will see.
