It is currently Tue Aug 12, 2025 5:37 am
PostPosted: Fri Dec 03, 2010 5:36 pm
This is the worse - three other surfaces have marks but the 'skin' is not broken - one surface has a mark and a small pit
Use or not to use?
David L
PostPosted: Fri Dec 03, 2010 6:17 pm
Mods rock!
If you were caught out in the desert with a broken CV, that one would be gold......
However since I think your at home, why not do yourself a favour and chuck that one in the bin.......
PostPosted: Fri Dec 03, 2010 7:24 pm
I haven't checked the other side - but do you normally replace both as a pair or only if damaged?
David L
PostPosted: Fri Dec 03, 2010 7:29 pm
Mods rock!
Complete CV joints either outright or exchange are not very expensive these days, although I have a strong preferance for new joints. Some of the re-built ones are not much better than the ones you take out.
Generally, I would only replace the one side if that is knackered, although, if I'm doing a ground up resto, then I do everything so it all starts off on the same foot. Depends too on how much $$$$ you wish to invest in your project and how much use it will see.
PostPosted: Fri Dec 03, 2010 7:51 pm
$55 each at Karcraft - may as well do both
David L
Users browsing this forum: No registered users and 70 guests
